Rubbing alcohol in windshield washer tank ?
Just would like to know if I can dump in some rubbing alcohol to prevent my windshield washer tank from freezing. Dropped into the 20's tonight, and and a little worried, I don't want to have my tank rupture because I still have summer wash in the tank.
I beleive they even sell some anti-icing washer fluid. Your fluid should never freeze, not in CT anyways. I've had regular fluid in my truck when it was -20* and it didn't freeze. When it's that cold outside you don't have to worry about the fluid freezing, you should be worrying about the washer jets even shooting out fluid in the first place.
I just read Shonne's post. And some of you may have heard of this before.
Supposedly if you let your hand sit in washer fluid for an extended period of time( I think it was 30mins) you will start to loose your eye sight. I guess something in the fluid absorbs in the skin and effects something in your head. Anyone know any truth to this? Or is it just another one of those acts needed to be debunked by Myth Busters?
http://www.setonresourcecenter.com/m...6/wcd046d3.htm
from what i learned the old term drinking yourself blind came from the old day with prohibition. people would drink washer fluid and antifreeze to get drunk because of the alcohol content and eventually go blind.
chaikwa.
A possibility in any product containing Methanol
http://en.wikipedia.org/wiki/Methanol
"Methanol is toxic by two mechanisms. Firstly, methanol (whether it enters the body by ingestion, inhalation, or absorption through the skin) can be fatal due to its CNS depressant properties in the same manner as ethanol poisoning. Secondly, it is toxic by its breakdown (toxication) by the enzyme alcohol dehydrogenase in the liver by forming formic acid and formaldehyde which cause permanent blindness by destruction of the optic nerve."
I used to make my own washer fluid from equal parts of rubbing alcohol, ammonia and water. That was some good stuff if you could stand the smell! Used to take off dried-on bugs in one or two swipes of the wipers! So I guess my answer would be 'yes', you can use rubbing alcohol.
chaikwa.
chaikwa.
Thanks guys, that eases my mind.
Methanol, ethanol, rubbing and isopropyl alcohol are not something I'd ever want to ingest. As stated earlier that stuff can make you go blind or be fatal.
Chaikwa, would you mind sharing your windhield wash recipe, sounds like a good one.
you can buy a de-icer additive to put in with your summer fluid. this is the first your i have used it. no problems with freezing so far. i think it is made by prestone, but i cant remember for sure
