Sponsored by:
Sponsored by: CARiD
Purging air from fuel system
Old Sep 15, 2005 | 12:22 PM
remarc31's Avatar
My lift pump has been relocated to the rear near the tank. If I replace the lift pump with a new one and its free of fuel, what procedure should I use to get rid of the air.
Old Sep 15, 2005 | 01:41 PM
farmer dave's Avatar
Is the new pump going to be run through the stock filter? If so I would start by cracking the bleed screw and bumping the starter. If the new pump is wired through the wiring harness then is will run for a while. Once fuel starts coming out close the bleed screw and try starting. If it doesn't start then you will have to crack the injector lines. Some say to only crack 3 at a time but I have never had any luck with that, I just crack them all. It is harder to get them all closed, but atleast you know that the air is out. It will run ruff until you get all of the lines closed and then it should smooth out.
Old Sep 15, 2005 | 07:53 PM
Vulcan's Avatar
I just bump the starter to get the pump running. Every few bumps I try and start it. I repeat the process till she fires. I fool with my fuel system a lot and this works every time.
Old Sep 15, 2005 | 08:23 PM
ftltmp's Avatar
I am sure this will get alot of slack. but what we do at work is loosen the fws top and take an air hose and blow into your vent line sloooowly until it starts filling the fws.Once you have it running you can release the fuel cap to release any pressure.I know we dont have any trouble, not sure if it will work on our system,although it should. Just my .02
Old Sep 15, 2005 | 09:46 PM
Patrick Campbell's Avatar
Where does the air go when you bump the starter??
I have to replace a HUGE fuel filter here in a few days that is located back by my tank, and I haven't figured out how I am going to do it. I was hoping I could just bump the starter and it would fill the filter up with fuel and then start up...
The system is entirely replaced from the VP44 back to the tank (no stock filter housing, no stock lift pump).
Old Sep 15, 2005 | 10:02 PM
fschiola's Avatar
It will move through the IP and return to the tank just like extra fuel would.
maddddog
Aug 16, 2019 07:20 AM
krowe111
Jun 21, 2011 09:22 PM
herb
Jul 18, 2008 08:25 AM
cLAYH
Jul 6, 2008 03:44 PM
joel
Apr 4, 2005 08:06 PM
