Sponsored by:
Sponsored by: CARiD
Propane/hydrogen injection?
Old Sep 28, 2005 | 07:01 PM
chaspip's Avatar
Has anyone out there added a propane injector to their Cummins? If so, how well did it work? Ever consider a hydrogen boost/supplement using the same apparatus? I would imagine a rather large icrease in fuel mileage. Considering how much fuel is going up riight now, I'm looking for alternatives that are safe, as well as efficient. Any thoughts?
Old Sep 28, 2005 | 07:14 PM
HOHN's Avatar
Propane is a good option for steady hwy cruising with a light load or empty. it can make your fuel stops a lot farther apart.
That said, propane costs money, and there's no free lunch. By the time you spend $750 for a very-high-quality MSD Digital Propane system, and THEN buy the propane, you'd be lucky to ever break even in terms of cost and fuel savings.
Propane is best for mildly setup trucks. If you have huge injectors and radical timing, it's not much more helpful. Unless you want to detonate a headgasket-- propane is great for that with too much timing!
jlh
Old Sep 28, 2005 | 07:53 PM
CSAGrey1's Avatar
jlh
What they don't tell you is that after you spend the $$ on the system you still have to buy the very $$$ tank. No; your regular run of the mill BBQ/RV tank is not an acceptable apparatus for this use. You need a vaporized petro tank rathaer than an LPG tank.
Old Sep 29, 2005 | 10:07 AM
Eskimo's Avatar
Ya sure about that? The few guys i know running 'pane use forklift bottles. I got my last one for $50, filled.
(And you catch the home Depot guy away from their fork... )
Old Sep 29, 2005 | 11:58 AM
CTD NUT's Avatar
The fork lift tanks are the correct style tank for propane injection or propane powered vehicles.....they are not the same as the BBQ LPG style tanks.
Old Sep 29, 2005 | 08:37 PM
Bart Timothy's Avatar
I don't know about the legality of it as far as DOT is concerned, but using 1 BBQ tank with an OPD valve doesn't put out much vapor unless it's a hot day. When the temps are in the 60's to 70's you only get about a 30 hp shot until the tank starts cooling off from use, then output starts going down. The OPD hose fittings are also too restrictive to use. 2 paralleled BBQ tanks with unrestricted hose fittings work much better.
Liquid systems are much more consistant in delivery that vapor systems.
The down side of a fork lift tank is size. It only holds 7 gals. Not enough for use on the highway.
Old Sep 29, 2005 | 08:41 PM
kingofdodge7131's Avatar
They make bolt on hydrogen cells for over the road trucks.... maybe look into those?
Old Sep 29, 2005 | 08:42 PM
I have seen a hydrogen injection sytem installed on a CTD before. It required 20 amps of juice to deliver enough hydrogen from water to make any difference in diesel fuel milage. The milage got eaten up by the extra power needed to run the alternator.
Flatbed24v
Jul 31, 2009 10:57 AM
trik396
16
Jun 4, 2008 11:50 AM
RollOver Pete
Sep 11, 2006 09:37 PM
chaspip
Oct 12, 2005 04:41 AM
PowerDually
Jun 12, 2005 10:51 AM
