Pluggin in the truck?
Got a question for all you cold weather guys. My Cali truck that rarley sees below 40* was hurtin this morn. Im in the Carson City NV area and it got in the LOW 20's last night. This morn the truck was hurtin, rough start, idled like crap for a long time etc. The question is, at what temp should I plug the thing in at night. If it gets down to the low 20's again tonight, should I plug er in. Thanks All,
Tom
Tom
Originally Posted by Willy91
It might be a good idea to plug in. We normally try to plug in for anything below 25 or so.
but yes i would recommend it.
Originally Posted by Ridiculous
it would be a good idea to plug it in for sure. 25degrees or below is correct but if it's gonna be 32 F. or colder i plug it in. especially since mine is on a timer which makes it more convienent.
I plug mine in when it gets below freezing. I use a timer and it comes on 2 hours before i leave for work. I read on here somewhere that the heater draws 4KW per hour, i think. Correct me if i am wrong.
scotte
scotte
I heard it was like 700 watts but that even seems high to me. 4KW would boil all the water out and couldn't be run on an ordinary 110v cord.
I just stopped plugging mine in. I really like having it ready to drive as soon as I start it. Just let the grid heaters cycle though and you shouldn't have a problem starting even without the heater. It'll just run a bit rough and take longer till you can go.
Edwin
Edwin
Hey thanks for the comments. Not to sound like a tard, but do you guys plug it in a couple hours prior to start in the morn, or do you plug in over night. Again, Ive never had to do this
Thanks guys.
Tom
Thanks guys.Tom
Thanks guys.
Tom
Thanks guys.Tom
Whatever you do, DON'T use ETHER! The grid heaters could cause an explosion.
Edwin
Thanks guys.
Tom
Thanks guys.Tom
So that fire breathin, soot monger of yours does not like the cold eh?
Did you load it with Howes meaner cleaner as we discussed??? Could gel your fuel if it gets cold enough!!!
Newbees
LMAO!!
Rick
Newbees
LMAO!!
Rick
At that temperature, that nice thick Yankee #2 Diesel was propably 90% of your problem. Look in the owners manual under fuel specifications. If you don't live in the area you are going to, make sure you get some #1 in there or some anti gelling product to keep things moving. Up here they Climatize the fuel, meaning it gets thiner coming from the refinery, as it get's colder, and thicker as it gets warmer. Last week, we moved from -37C fuel to -34C fuel at the Petro-Canada bluk station. An uncle of mine was telling me of a pass through the mountans West of Creston, British Columbia where people have gone through, (really high atitude and nighttime make for some weird cold spots even in the summer) and had the fuel in their trucks gell up so bad they had to turn around or even be towed out. He said that the last fuel stations on either side of the pass, only run #1 diesel all year to keep people from running into this problem. How much of that is bull, I can't say, but it does get darn cold up here in some places. And some are worse than others.
