Piston Lift-pump Specifications
Can anyone provide the specifics for the following piston-lift-pump part numbers, i.e. pressure and application, etc.
1. # 3936318
2. # 3936323
3. # 3936320
4. # 3936316
5. # 3917998
Thanks for any information.
1. # 3936318
2. # 3936323
3. # 3936320
4. # 3936316
5. # 3917998
I looked for that too a while back and couldn't find anything. I did find reference to a higher volume lift pump I think 3936319??? but never could find specs for any of them. I do know that the 3936318 and 3936316 look almost identical, but the ports on the top are different sizes.
I bought the wrong one from Ebay a while back and had to get the other one to hook up to my truck.
3936323 only info give is it was used on 4cyl B models.
3936320 used for the Lucas CAV DPS pumps on 4cyl B models Flow is 108-230 LPH at 1250RPM
3936316 used for Bosch P3000 pumps on 4cyl B models Flow is 183-229 LPH at 1250RPM
3917998 no information found.
How about the pressures these pumps produce??
I think if this information can be found that it should be incorporated in a STICKY somewhere.
E-BAY, and other sources, abound with real tempting prices on piston-lift-pumps; but, one is kind of buying the proverbial pig-in-a-poke not knowing the flow and pressure statistics on the various part numbers.
Thanks.
surfram
0
Feb 19, 2007 09:12 AM
Bobcat698
Nov 29, 2006 05:47 PM
Svenne
0
Jan 19, 2004 01:54 PM
Copenhagenjunkie
Jan 4, 2003 11:54 AM
