Sponsored by:
Sponsored by: CARiD
painting a turbo
Old Mar 27, 2006 | 10:33 PM
magnusrw's Avatar
painting a turbo
Howdy,
I'm going to set about rebuilding a turbo (a Schwitzer 3LM I mentioned in an earlier post) and have a few questions. When I have it apart, I plan to clean it thoroughly and then paint the compressor housing (outside only I guess). What of the turbine side? Should I just leave it bare or paint it and let it burn off? Is there any coating that is worthile to put on it? Gunblue (just a crazy idea)?
Thanks
Old Mar 27, 2006 | 10:51 PM
edwinsmith's Avatar
I suppose you could paint it with high temp header paint. White would look pretty good. I seem to remember a graphite paint that some use. It doesn't hurt a thing to just leave it "natural". Don't paint the inside of either the turbo or compressor. It's made to be unpainted.
Edwin
Old Mar 28, 2006 | 09:23 AM
spunbearing's Avatar
VHT is good for 1300-1400 degrees and comes in a variety of colors.
Old Mar 28, 2006 | 12:47 PM
usmc2311's Avatar
This company makes a few products that might be of use to ya. Never used them myself so can't provide any 'expert' knowledge, but just something to check out.
http://www.techlinecoatings.com/Exhaust.htm
Old Mar 28, 2006 | 12:55 PM
RustyJC's Avatar
If you want to pay some fairly serious $$$$ for something that will last, check out Jet-Hot coatings.
Rusty
Old Mar 28, 2006 | 03:44 PM
PanteraGSTK's Avatar
would powder coating stand up to the temp?
Old Mar 28, 2006 | 04:17 PM
SoTexRattler's Avatar
Go to NAPA and look for the aerosol can of Dry Graphite Film (DGF-123 brand)with NAPA's label.
Spray a liberal coating on the cleaned cast iron part. It dries almost instantaneously and sticks real well. It'll stand the heat and it looks like grey cast iron. I did it to the top of my manifold when I put my EGT probe in and it still looks good considering I didn't get it all that clean before I sprayed it.
K.
Old Mar 28, 2006 | 04:40 PM
http://www.pitstopusa.com/detail.aspx?ID=1633
That's a link to the VHT paint I was talking about. You should be able to buy it off the shelf though. What happened to the guy on here about a year or so back that was doing the ceramic coating?
Old Mar 28, 2006 | 11:24 PM
magnusrw's Avatar
Wow, the price sure is right on that VHT stuff! Any one have any tips on where I'll be able to find it on the shelf? If not, i'll look into getting some of that dry graphite coating from NAPA. Thanks for the input fellas!
Old Mar 28, 2006 | 11:26 PM
magnusrw's Avatar
One more thing, is that VHT stuff something that has to be baked on? I understand some of those coatings require you to bake whatever it is you've painted for a couple of hours.
Old Mar 29, 2006 | 09:41 AM
http://www.speco.com.au/vht_faq.html
Theres the instructions. They do recommend that you get it up to temp. You could bake it or you could probably just drive the truck gently around town.
I haven't used that stuff for about 10 years or so but I was very impressed with it. Matter of fact maybe I should do my exhaust manifold and turbo next time I have it apart.
atc250r
15
Sep 15, 2005 01:39 PM
AggiePhil
17
Feb 25, 2004 08:30 PM
dodgediesel4x4
Feb 12, 2004 03:45 PM
Mostwanted
Jan 18, 2004 01:21 PM
hellotbone
Apr 30, 2003 05:12 PM
