Sponsored by:
Sponsored by: CARiD
'Ole Restrictor Thing
Old Dec 18, 2006 | 06:07 PM
59FORD's Avatar
OK, I got bored and a new saw blade......then my mind started to wonder....
uhhhh that's not good, believe me.
We have all heard about the restriction in the intake to Number 1 cyclinder. Well that's where my mind went.
So I did a cut-away to show everyone the culprit and how much you CAN remove during a rebuild.
The only thing I noticed is the "hump" is drilled and tapped. I see no problem
in removing 90% of this obstruction. You could always thread a small plug in the hole.
There is plenty of meat around the casting with no water or oil near, there is
a head bolt in the area but not close enough to worry about. In the second pic
you can see the paper I stuck in the hole to show the reference to the head bolt.
THE PICS ARE 800X600 QUITE BIG FOR DIAL-UP
You are looking at about 10 minutes of work thanks to Porter-Cable. I was amazed
at how much you could grind away without fear of ruining the head.
Now everyone can see.
Have saw will travel
59
Old Dec 18, 2006 | 06:25 PM
Very nice! Everyone get out your die grinders...
Old Dec 18, 2006 | 10:24 PM
97ramctd's Avatar
59
Come on up! would like to see bigger pictures so i could do it, as i cracked no1 exhaust port where the manifold bolts due to heat. would this help with heat?
Old Dec 19, 2006 | 05:43 AM
59FORD's Avatar
Just click on the pics they are linked to larger images.
I have even larger pics on file. I scaled them down to save
some time loading them.
BTW, from where I live it would be "come over to Missouri"
59
DMcPherson
Jan 6, 2009 09:13 PM
Bobcat698
Jan 15, 2008 03:35 PM
bigfish
Jun 6, 2004 09:13 AM
Fishbait
Nov 8, 2003 05:42 PM
