Sponsored by:
Sponsored by: CARiD
oil leak
Old Jul 31, 2005 | 09:52 PM
tthomass's Avatar
oil leak
looked under a truck i'm about to buy and see oil, no worry as what engine doesn't but things seemed coated pretty good, maybe even drip...........i've heard stories like "what diesel doesn't, they all do blah blah blah".........so, 2000 Cummins 50k miles
do you leak? how much?
Old Aug 1, 2005 | 02:04 PM
tool's Avatar
where was the oil? around the breather hose? Below the vacuum pump??? where did it look like it was coming from?? Definitely something to check out before you buy.
Yes Cummins engines are known to slobber some oil here and there.
Old Aug 1, 2005 | 03:20 PM
farmer dave's Avatar
I just fixed my oil leak on the vaccum pump. I had to get a rebuilt pump because the seal kit I got didn't work. It was a constant drip. This could be the problem. I would definately narrow it down before I bought it, if I did buy it.
Old Aug 1, 2005 | 03:26 PM
tthomass's Avatar
believe its the oil breather or whatever behind the radiator, so says Dodge on the phone since its prob never been cleaned out, truck is be'n checked out this week
Old Aug 1, 2005 | 09:28 PM
Make sure that this is the problem. The vaccum pump can leak and it looks like the breather at first. Look at the shaft between the two pumps, if it is wet the this is the source. Also make sure that it isn't a bad seal somewhere else.
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
