Sponsored by:
Sponsored by: CARiD
need tires, recommendations
Old Mar 30, 2008 | 09:39 PM
jj3500's Avatar
I'm needing tires for my 89 dump truck. Don't want to go too pricey with this expenditure. Last time I purchased tires, I bought six from Costco. They ran under a hundred per tire. I thought it was a great deal. Now, same tire, its $135 or so. Anyone have recommendations on a not too pricey tire.
Old Mar 30, 2008 | 09:45 PM
HOHN's Avatar
It worked once, why not twice?
Old Mar 30, 2008 | 10:58 PM
johnny5.9's Avatar
Cheap is good but poor quality isn't. Tires made in China are known for tread separation. Stick with reputable brands, preferably made in the US. Better quality tires balance out better and thus last longer anyways. You get what you pay for. And there are few things on a vehicle that contribute as much to safety.
Old Mar 31, 2008 | 08:33 AM
Dartmouth 12V's Avatar
What do you do with the truck? Is it a highway queen or does it go in the mud and brush?
The longest lasting tires seem to be michelin LTX but they do cost more up front and are not good in the mud or snow.
Old Mar 31, 2008 | 10:53 AM
jj3500's Avatar
tires
Its a dump truck. Lots of around town trips. Will not see more than 500 miles a month. It will be in gravel an hard pane surfaces mostly. Other than the trip to the quarry....gravel or top soil.
Old Mar 31, 2008 | 06:46 PM
johnny5.9's Avatar
Nitto dura grappler if traction is not a concern. For my truck I'm seriously considering Goodyear Workhorse Extra Grips. They seem to have a fairly aggressive tread design while retaining good wear characteristics. They're also designed with work trucks in mind. (Cut resistant compound and high load capacities.)
Toyo open country at are terrible for wear on heavy trucks. The compound is too soft. Look into Hankook Dynapro ATM RF10 (or another of the dynapro line). The RF10's seem to have a good balance of all terrain design. I hope this helps.
Old Mar 31, 2008 | 06:57 PM
jdwest's Avatar
Mastercraft Courser AT2 all terrains. They're made by Cooper. I've got about 5k miles so far. Pretty good tire for the money.
Old Mar 31, 2008 | 09:32 PM
cjdakota's Avatar
Smile
I have the Cooper Chapperals and I now have about 10,000 on them without much wear. They are quiet, smooth and have a good cleanout design. Give them a look see. I paid $150 each.
Old Apr 1, 2008 | 09:02 AM
Unless you need the added traction of a true A/T tire, I would get either the Michelin LTX or the Firestone Steeltex. Both wear quite well and handle a load very well. The initial investment is higher but they last an awful lot longer.
Old Apr 1, 2008 | 10:54 AM
HOHN's Avatar
What dartmouth said.
Most of us that run an A/T tire don't need them since we're mostly on pavement.
To me, winter traction is the main reason to consider an A/T tire over a hwy tire.
In the long run, a hwy tire is a better value because of the long treadlife and better mpg.
At least, that's USUALLY true
Old Apr 1, 2008 | 11:53 AM
96_12V's Avatar
My truck has Michelin LTX's, as of Spring 2007. These are load range E - which should mean "Expensive." There's just not a lot of way around this fact - load range E tires simply cost more to construct, and those costs just keep rising. Is this a business truck? Maybe you can itemize the expense of upkeep on your taxes. I tried to find something under $120/each, I finally gave up and bought the good ones at Sam's, since safety is a huge priority, and it's hard to justify questionable tires.
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
04ctd
0
Jul 9, 2006 04:44 PM
Captain
Sep 9, 2005 12:16 AM
