Need Ford Advice (7.3 IDI Engine)
I owned three of these diesels and all of them got over 15mpg city and near 20 hwy turboed and the pump turned way up. I really dought that the tach sensor had anything to do with the miss beings that is an all mechanical pump and is not even connected to the tach. I will bet you are slow in time or have pump problems. Best thing to do with the glow plugs is pull all the plugs install autolite 1106 plugs put a switch on the relay so you can turn them on manually and you will never need another glow plug and the never swell these are a 12 volt plug instead of the original 6 volt it takes about 30 seconds in the winter to heat them up to be able to start but you will never have to replace another.
CTD NUT
May 15, 2006 05:49 PM
