Sponsored by:
Sponsored by: CARiD
7.3 Idi
Old Aug 28, 2005 | 02:03 PM
GTSMKD's Avatar
7.3 Idi
Does anybody know how to turn the IP up on a 1991 Ford 7.3 IDI.
Old Aug 28, 2005 | 08:36 PM
suzukiZrider's Avatar
yup look at the ip and there is a cover on the side when you take off the cover that held on by 2 bolts you will see inside the pump once you see inside there should be a hole that has a 5/16 allan inside it start by turning the allan one flat and go from there keep an eye on EGTs they can get real hot real quick with these motors and stuff can go wrong quick so get a pyro before even touching the fuel i got some pics of how to do it somewhere i just got to find em
Old Aug 28, 2005 | 08:41 PM
TxDiesel007's Avatar
If you go
about two turns, thats almost max for this fuel pump, i did the same thing to mine, and it will run so much better, you wont be on the throttle as much due to increased fuel and the fun factor will be there, BUT ur egts will be hot.
Tx
Old Aug 28, 2005 | 09:02 PM
http://www.members.shaw.ca/k2pilot/I...%20article.htm
theres the link i was looking for it will tell you exactly how to do it and i was close its a 5/32 not a 5/16 like i said before but theres the link good luck if you need any more help just give me a shout
csramsey640
Sep 29, 2006 05:31 AM
CTD NUT
May 15, 2006 05:49 PM
Txwelder
May 11, 2004 04:14 PM
Stamey
Apr 4, 2004 09:32 PM
