Sponsored by:
Sponsored by: CARiD
Military Trucks
Old Jan 21, 2005 | 12:30 PM
Kyle Graham's Avatar
Military Trucks
Just placed my bid on a 82 Kaiser Deuce and half 6x6 If I win the bidding war I will be swapping engine with a 2001 24 valve cummins somewhere around 500rwhp. I plan to restore it all back to original aside engine and some Dual chrome stacks. What do you guys think??
Old Jan 21, 2005 | 12:55 PM
96_12V's Avatar
If that doesn't work out for you I have personally seen the 6-wheel millitary truck at threelakestruck.com in Northern Wisconsin. Except for the chassis, engine and cab being repainted red (??) it's in excellent shape. On the "truck page, about half way down.
Your project sounds awesome!
Old Jan 21, 2005 | 01:46 PM
wingnut's Avatar
Just make sure the rest of the drivetrain can handle the power.
While on a convoy in Bosnia I personally snapped the driveshaft in 2 (in the middle not a U-joint) on a loaded 5-ton simply by pushing the GO pedal too hard.
Old Jan 21, 2005 | 01:50 PM
Mechanos's Avatar
If it's a military truck and you are going to restore it to military paint scheme, etc. chrome stacks would just look dumb in my opinion. Chrome and flat paint just don't go together..... but flat black stacks would be cool.
Old Jan 21, 2005 | 02:43 PM
CTD NUT's Avatar
If 5 ton rockwells and drive shafts can't handle the power then I have no idea what will!.........2.5 ton Rockwells seem to put up with an insane amount of torque when properly built so I can just imagine how much jam a 5 ton will hold up to.........the only suggestion I would have is if the truck has 2.5 axles, you may want to make sure that the axle joints are Spicer/Rockwell u-joints instead of those goofy Rockwell/Timken joints (can't remember what they are called but they are not universal joints) that grenade easily and wear out quickly........I have heard of many guys swapping axle shafts to ones that accept u-joints because the Timken joint junk would blow up too easily and was not up to par with the rest of the axle..........I think companies like Military 6X6, Avalanche Engineering and Poison Spyder Customs can help with 2.5 ton axle shaft mods.
just my .02
Old Jan 21, 2005 | 02:58 PM
That is what I was thinking those trucks have the strongest drivetrain on the planet gotta love those Rockwells. If I lose the bid I'll just try again this one is close to me about 10 miles away where most of them up for auction are in Texas and further east.
Old Jan 21, 2005 | 03:32 PM
Eskimo's Avatar
I'd use a bigger engine than a 5.9 liter. Those are HEAVY trucks!
Old Jan 21, 2005 | 04:32 PM
DZLPWR's Avatar
Swap in a Cummins 8.3L. You can even bomb it!
Old Jan 21, 2005 | 04:47 PM
Mechanos's Avatar
Originally posted by CTD NUT
...those goofy Rockwell/Timken joints (can't remember what they are called but they are not universal joints)...
I believe those are called Tracta joints.
Old Jan 21, 2005 | 05:05 PM
gsdog1's Avatar
An 8.3 under the hood and black stacks would definitely rock!
Matt
Old Jan 21, 2005 | 06:07 PM
I'm really thinking a twin turbo 550hp 5.9 will move it with ease this one has a 5.9 mulitfuel in it right now stock and it does run
Old Jan 21, 2005 | 07:12 PM
charger 69's Avatar
Matt
What is an 8.3 used in?
Old Jan 21, 2005 | 07:39 PM
Medium duty trucks mostly.
Old Jan 21, 2005 | 10:36 PM
Mechanos's Avatar
Matt
Oh yeah..... a tweaked and twisted 8.3 with either a woodland or desert flat camo paint job and flat black stacks.....
Old Jan 21, 2005 | 11:47 PM
Ripper406's Avatar
8.3 stock 300HP 900lbs tq, tweak it up and you'll pass up 500HP and be in class 8 Semi truck tq territory.
