Sponsored by:
Sponsored by: CARiD
Marine Cummings 302
Old Feb 9, 2014 | 05:54 PM
wilperson's Avatar
Marine Cummings 302
Does anyone know much about marine Cummings 302? They are in a 1974 pacemaker yacht. I can't find much info about their dependability. If parts are still available.
Old Feb 9, 2014 | 08:04 PM
Dieselbuilder's Avatar
do you mean 509?
Old Feb 9, 2014 | 08:20 PM
wilperson's Avatar
I was told it was Cummings 302 but I can't find any info on that motor any where.
Old Feb 9, 2014 | 08:21 PM
6cylinders's Avatar
Post a pic,,,,I really want to see that " G "
Old Feb 9, 2014 | 08:24 PM
wilperson's Avatar
This what I was told is in this boat.
Twin 302 Cummins engines non aspirated diesel - 300hp @ 1800 rpm, fresh water cooled
I saw the motors but didn't really look at them that close, I was browsing at that point.
Old Feb 9, 2014 | 08:28 PM
6cylinders's Avatar
V-8's ? Big sized, like bigger than a 8-71 Detroit and way bigger than a 3208 CAT?
Probably 903 Cummins for that power at that rpm.
Old Feb 9, 2014 | 08:31 PM
6cylinders's Avatar
http://grabcad.com/library/cummins-vt-903-m-engine--7
Old Feb 9, 2014 | 08:32 PM
wilperson's Avatar
I just sent the seller a message, he told me several times 302 Cummings
Old Feb 9, 2014 | 08:34 PM
6cylinders's Avatar
http://nationaldieselengineinc.com/w...ins-Engine.jpg
or smaller, this is a 555 Cummins, often called - triple nickle
Old Feb 9, 2014 | 08:35 PM
Dr.Dizzle's Avatar
There is no "G" in Cummins.
6cylinders's Avatar
I had a 903, it was rated @ 290 HP, it used a lot of fuel .
Maybe it's a inline 6 cyl.,
yes 555 and 903 parts are getting a little hard to come by,
although you can get lots of military surplus 903 stuff.
Old Feb 9, 2014 | 08:36 PM
wilperson's Avatar
I hope it's not the triple nickels in this boat, because I hear you can't find parts for that motor
Old Feb 9, 2014 | 08:42 PM
wilperson's Avatar
Well I hope it's a simple error, and they are not attempting to mislead me.
Old Feb 9, 2014 | 09:07 PM
Hvytrkmech's Avatar
Marine applications are usually rated in HP. Displacement is the real question I'm seeing here. The 555 or triple nickel was rated out to 300 hp. However, they are the best anchors made. Read junk into that. Dig into it further prior to pulling the trigger in any sale.
Best of luck.
Old Feb 9, 2014 | 09:09 PM
wilperson's Avatar
Thanks for the feed back I will definitely dig lol.
Here is a reply they just sent me, does it hold water?
These are back in the days when they used truck engines, commercial refrigerator diesels, tractor and farm equipment diesels and converted them to diesels for marine. They also used military engines like the Catapiller that were developed actually as a throwaway engine but turned out to be one of the most solid engines of all time . I can only give you a list of the modern engines and you can compare and see how they rate with this engine. I also use resources such as retired merchant marine mechanics and they give me the stats as well. That way I double checked my research and they are the best resources since they've done it for many many years. But it's more like they know the engines like the back of of your hand rather than looking into technical data that has not been recorded on the Internet.
