Mack Injector Lines
Mack Injector Lines
Hi, I have to change my leaking line or lines on my DM 300,and was wondering if there was a special socket that would help in removing and reinstalling the lines at the injector? It looks to be to close of quarters to get a wrench on them.I'm thinking crowfoot flare nut wrench right now,unless there is a better way. I will have more questions on this truck as time goes on,as I can't get much of a response on the Mack site
TIA Joe
TIA Joe
I took a box end wrench and cut a channel in the end of it that was just big enough to fit around the injector line, (like a line wrench), then I ground down the sections on the left and right of the cut just enough to make using it easier.
Good luck
Good luck
Hey there bumpy, I always use just a regular open end Flank Drive Plus Snapon wrench on them. You just got to get at them the best way you can. I do suggest removing the dog house for the 5 and 6 lines but I bet you already know that!
What he said up above! Take the air cleaner pipes off. Its worth it!
You can buy inector line sockets if you need to, but a good open end wrench will do the trick. Some times those things will get seized on there pretty good but give it a shot! What do you have to loose?
I'm waiting for my lines to come in,and was just getting all my info and special tools in order,before I start the project. And I tried the wrench on all the lines at the pump and all came loose,and I then retightened em. I was able to loosen the the two front ones at the injectors as well but I was unable to access the rest without tearing down the air intake,I'll wait till I have all the parts.
