Sponsored by:
Sponsored by: CARiD
Looking to get a diesel truck..
Old Oct 10, 2005 | 10:42 PM
drew03's Avatar
mine doesn't but i could have got one.
Old Oct 10, 2005 | 10:47 PM
phox_mulder's Avatar
Originally Posted by Sublimize23
thought of antoher question. what kind of police attention do you guys normally recieve driving trucks?
There's a couple guys around here that are constantly being "harrassed" by the police for lift violations, they are well within specs, in fact have the same height I do, I have never had to deal with them, but carry a copy of the Utah lift laws in my glove box, just in case.
I will miss parking in tight parking spaces though. how do you guys handle parallel parking?
If you lift it just right, the rear bumper clears the hood, so you back up till the tires contact the grill,
then pull forward till the front tires do the same to the trunk.
Any rubber marks come off with a wipe of a paper towel.
phox
Old Oct 10, 2005 | 10:49 PM
Sublimize23's Avatar
phox
LOL! I'm a senior in high school, and unfortunately, most people my age have no idea how to drive. someone scraped the side of the xB in the parking lot, and someone else tapped into it backing up. not to mention vandalism i've recieved... but that's another story.
Old Oct 10, 2005 | 11:12 PM
displacedtexan's Avatar
haha! do the rams have an 8ft bed like the F-series?
Yeah, only it's better, cause it's on a Dodge...
The beds are either like 6'6" or 8'...
Old Oct 10, 2005 | 11:23 PM
one more question. I'm hearing about "VP44" failures. I'm assuming it'ss ome kind of pump on the engine? could someone clarify?
Old Oct 10, 2005 | 11:36 PM
drew03's Avatar
i am not real sure, if it is not a problem with a 3rd gen then i don't really pay attention. you might try to do a search on it.
Old Oct 11, 2005 | 07:58 AM
It's the injection pump on the seccond gen 24v... They are somewhat trouble prone, seems to be luck of the draw, some top 200000 with theirs fine, some replace 3 before 100000... Like drew said, if you search it you will find LOTS of reading, VP-44, the Bosch injection pump.
Old Oct 11, 2005 | 10:59 AM
96_12V's Avatar
Dullies are much more difficult to drive in snow. It;s the tire contact area factor.
Wow, you drive a new Scion in high school, here's what I drove back then:
http://www.sdsuniverse.info/Upload/P7170003.jpg
Old Oct 11, 2005 | 01:13 PM
sparky3008's Avatar
Hi all, new here. In about a year or so, I'll be looking to buy a full-size diesel truck, and I have a couple questions.
1) The only thing I have to tow is a trailer that holds 3 dirt bikes, gear, etc. I've always loved trucks, and I am mostly going to use it as a daily driver, am I crazy?
This is a personal choice and I as you don't need a full size medium duty truck I wanted one...
2) I plan on getting a dually, because I love the way they look, and they have a much stronger rear end. is there anything I should know about?daily challenges, etc
Dully are many time bought by people who really don't know anything about them. The dually is actually rated at less weight that the single 3500. The reason being no suspension or brakes etc were changed and with the addition of the two tires that counts towards the overall weight. Plus duallys are really to stabilize heavy trailers so your truck isn't being manhandled by what you tow. If you are just pulling a few motorcycle a dually is unnecessary. Also as some have stated finding parking for a dually is a pain and driving one takes skill as well. Not worth it in my opinion.
3) I'm also looking at 1999-2000 Ford F-350's (yes, I admit it, I'm a Ford man..), what are the advantages of the ram with the cummins over the powerstroke?
With the money you are talking about you are looking at a 7.3 and an older 12v cummins most likely. I can only speak for the 7.3's as I used them a lot for many years. When international put the turbo's on them they became a much more reliable engine as before without they would build too much compression underload and crack heads. My brother-n-law had an older 7.3 and now has a 2nd gen 24v cummins and was the best move he ever made. Comparing the 2 in my opinion the cummins is a real truck engine and the 7.3 is a gas block turned diesel no comparison...
4) what kind of highway MPG can I expect? for those in the DelMarVA region, what are you currently paying for diesel? one thing I like about diesel is that the price rarely fluctuates.
I am in Maryland and fuel goes between being below 87 to inbetween 87 and 89. The only way to compare would be to get the power of my 03 diesel I would have had to buy the V10 which gas mpg is no comparison and a no brainer.
5) I've heard a lot about fuel gelling. what is done to prevent this? what happens when your fuel gels? what do you do when it happens? I'll be going to college in southern VA next fall, and that's when I plan on buying the truck. it doesn't get too cold down there, but there is the occasional snow.
In areas where it gets cold the fuel has an additive added automatically as the seasons change. I have always driven diesels in Maryland and have never added any anti-gel other than what is in the fuel already. They do sell anti-gel additives that you can add to this if you wish. If the fuel gels it becomes like jello and will no go through your injectors and such. I have never had a problem...
6) I've been driving 5 spd for a while, and I'd like to keep it that way. Is there anything I should know about clutch/transmission wise? I've driven a few F-350's and chevy 3500's ( ), but they were all auto.
If you get a Dodge with the 6 speed you should have very little problems. That transmission is bullet proof and if the person before you raged it I would say replace clutch and that thing will last a long time.
7) finally, my budget is about $13,000, what year/model ram do you think I'd be able to afford? I'd like a laramie if possible.
thank you very much, and I eagerly await your reponses, and I will continue my own research.
VP44 is after the lift pump. The lift pump takes fuel from the tank and sends it low pressure to the vp44. This pressurizes the fuel and sends it to the injectors. Many times what happens is the lift pump fails starving the vp44 and the vp44 burns itself up as it uses excess fuel to cool itself... (I am new to this and could be wrong but is what I understand about it).
Old Oct 11, 2005 | 02:02 PM
cool, thanks for clarifying. what kind of fuel pressures do these trucks run? I'm used to working on small-block Fords and 4 cylinders.
Old Oct 11, 2005 | 02:22 PM
sparky3008's Avatar
This is not written in stone as with modifications and such you will get different readings. These are one guys readings, 16 idle, 14 cruise, and 10 WOT. As long as the fuel pressure doesn't go below 8.
I have seen some mention numbers as high as 20.
tbreddiesel
Jul 21, 2015 07:28 AM
az2500
Apr 21, 2010 08:53 PM
bob95065
39
May 7, 2007 09:48 PM
LanceK
Apr 13, 2006 06:32 PM
