Sponsored by:
Sponsored by: CARiD
Little Diesel Generator
Old Aug 13, 2012 | 08:49 AM
bannerd's Avatar
Hey guys, I have a small diesel generator that I've been trying to fix. The gas tank had a rubber seal that is destroyed (old age). The new seals is about $110 and I never really like the design of it anyways. So I came up with a solution but it has failed and now I'm looking for any ideas anyone has. Here is what I did;
Old Aug 13, 2012 | 10:31 AM
infidel's Avatar
Try using Permatex #2 from the auto parts store on the washers after cleaning all surfaces well.
Old Aug 13, 2012 | 10:55 AM
Colo_River_Ram's Avatar
With age comes the cage
You said you used pipe fittings from the hardware store.. Was it a bulkhead fitting like the one in this thread?
https://www.dieseltruckresource.com/...k-t299151.html
Old Aug 13, 2012 | 02:39 PM
bannerd's Avatar
It wasn't a fitting like that, the nylon washer pretty much screwed into the threads of the brass nut and 90 degree barb. I put some silicon in there and wrenched it down. I was thinking with the nylon washers it wouldn't even need silicon to stop the leak. Where would I get something like this? Maybe I'll try that #2
Old Aug 13, 2012 | 03:05 PM
The link in post 5 for glacier diesel shows a better fitting, you might try them and see if they will sell you the fitting only or do a Google on bulkhead fitting. Just make sure you get a diesel compatible gasket.
Old Aug 28, 2012 | 12:02 PM
irocpractice's Avatar
That seal would probably be Viton or Buena N,both are pretty much indestructible and suitable for most organic solvents.
Old Aug 28, 2012 | 05:38 PM
.boB's Avatar
Weld a steel plate to the bottom of the tank. Drill and tap for a pipe thread. Then you can use pretty much any pipe fitting you like.
Old Aug 29, 2012 | 12:12 AM
pind's Avatar
if it is a steel tank, then just get a weld in bulkhead fitting, or a weld in bung, and knock yourself out with all the options for feed lines from that.
MoparMarv
Sep 26, 2006 10:33 AM
12valve@heart
Aug 22, 2006 09:26 AM
walexa
Sep 22, 2005 07:34 PM
dansel
Feb 3, 2004 06:16 PM
Jack Thorpe
Aug 7, 2003 12:36 PM
