Sponsored by:
Sponsored by: CARiD
Knocking
Old Sep 25, 2005 | 07:01 PM
smokinorbroken's Avatar
Knocking
i have several questions. i just got my 6.2 back in the truck and running and it is still knocking. its not an oil prob, and the main and rod bearings were replaced. what could make it do this? could it be bad fuel or the injector pump? any suggestions on where to start?
Old Sep 25, 2005 | 07:08 PM
Jeremy Cusick's Avatar
Inj pump, wrist pins loose, rod journals out of spec, valve train, fuel pump (if it's mechanical), clutch (if it's stick shift). Take your pick!
Old Sep 26, 2005 | 09:23 AM
does anyone know how much pressure the fuel pump(mechanical) should put out? also do yoh have to remove the intake to replace an injector pump?
Old Sep 26, 2005 | 11:38 AM
tmleadr03's Avatar
Normal fuel pressure 38-45 kPA (5.5-6.5 PSI)
Normal fuel volume 237 ml (1/2 pint)
Old Sep 26, 2005 | 12:06 PM
how can i check that? should i go ahead and replace the injector pump or try something else first? i know it isnt the wrist pins becuase i checked them when i had the crank turned and replaced the bearings which i initially thought was the problem. now that i have eliminated all except for injector pump, injectors, or bad fuel(if that is possible).
Old Sep 26, 2005 | 01:03 PM
Haulin_in_Dixie's Avatar
I am in the same spot with my Cummins, only I have replaced the fuel system and head also. Discribe the knock, I am just curious, I have no answers for you.
Old Sep 26, 2005 | 03:18 PM
Is it your first 6.2? Those things always rattle something awful, are you sure it's abnormal?
Old Sep 26, 2005 | 07:15 PM
Yes, this is my first 6.2 but it is definantly abnormal. when I first got the truck it ran fine. I was driving to school one morning when it started I was sitting at a stop sign. I thought I lost oil pressure and I had already come to close to locking up the engine so I parked it and started the rebuild from then till now. now that it is all back together it still knocks. I put a pipe to the valve cover and listened to the rocker arms and everything is fine. it sounds like rod bearing knock but it is coming from the cylinders. I went and bought a haynes manual today and it has a troubleshooting guide that specifically says rapping noise coming from one or more cylinders sounding like rod knock, and its saying it could be the injectors. That leads me to my next question. Where do I get them tested?
Old Sep 26, 2005 | 07:23 PM
crobtex's Avatar
I don't know if they all can test injectors for light trucks, but most 18 wheeler repair shops have injector testing equipment. One down here tested the injectors off my 3 cyl Perkins.
Old Sep 26, 2005 | 07:29 PM
any GOOD diesel shop should be able to either test em or tell you where to take em. You sure it isn't piston slap?
Old Sep 27, 2005 | 11:52 AM
yes i'm pretty sure that it isnt piston slap. when i had it apart the pistons felt how they should have, and the wrist pins weren't loose, so like i said its either the injector pump or injectors.
TruckerGirl
16
Jul 19, 2004 01:08 PM
local601
14
Jun 1, 2004 12:20 PM
wantabee
Mar 14, 2004 09:22 PM
BamBam
41
Sep 19, 2003 09:48 PM
BamBam
Feb 24, 2003 02:43 PM
