Sponsored by:
Sponsored by: CARiD
I've never driven a diesel before
Old Nov 2, 2008 | 10:14 PM
  #31
Equalizer 2's Avatar
Don't know if you can incorporate a turbo timer into the A Pillar but WesTach makes a combo Boost/EGT gauge and with SRT A Pillar it make a clean install in 3rd gen trucks.
As stated use the block heater for 2-3 hours prior to starting (put it on a timer) and it makes a big difference in warm up times. It doesn't generally get below 32* here very often but I idle for about 4/10 of a mile to the hiway and by then the fluids are starting to warm up. When I leave there isn't much in the way of traffic for that 4/10 of a mile.
Old Nov 3, 2008 | 06:57 PM
  #32
Willy91's Avatar
Originally Posted by Butchy Boy
The diesel, I took some industrial diesel schooling at uti, however its all about stock, and I was thinking you could get more preformance probably if you had wet sleeves versus just a regular throw away block.
no need to bore anything out, well over 1000 HP can be made on stock sized bore.
Old Nov 4, 2008 | 11:24 AM
  #33
96_12V's Avatar
I'm also going to wind up replacing parts anyhow, probably boring it out, adding sleeves getting preforance pumps and fuel filters etc.
In about 5 years on this forum, with the possible exception of someone doing a rebuild and needing to sleeve thier block, this is the first time I've ever heard of anyone thinking of boring out thier 5.9. It's not 60's muscle car gas V-8. You won't need to bore it out - and to do so would be highly determental due to the much higher compression ratios and associated stress on the engine.
Old Nov 4, 2008 | 11:36 PM
  #34
Butchy Boy's Avatar
The bore wouldn't be for a preformance gain, so much as protecting the block if you blow a rod. All the industrials run it that way
Old Nov 5, 2008 | 10:46 PM
  #35
Tate's Avatar
Although the CR rods are considered weaker than the older rods (different casting methods), they are still holding 1100+ hp. Morkable, a member on here, did over 1000 hp and ran a 10.84 all on stock internals on his truck. Only real casualties have been numerous trannies and his turbo.
Old Nov 5, 2008 | 11:07 PM
  #36
6speedcowboy's Avatar
Unless you go to the extreme you really don't need to worry about he rods. It isn't possible to have a wet sleeved B series cummins. The only sleeves that you can put in to a B series block are repair sleeves but those are pressed into the cylinder after it has been bored oversize.
Blake West
21
Feb 7, 2013 08:33 PM
redneckonthenet
Feb 28, 2005 10:01 AM
mymaur
Jan 14, 2003 08:29 PM
Tackdriver
Jan 9, 2003 06:11 PM
Jeepnomore
15
Dec 12, 2002 09:01 AM
