Interesting comment on diesel fuel and injection pumps...
#46
Re:Interesting comment on diesel fuel and injection pumps...
[quote author=AlpineRAM link=board=8;threadid=14654;start=45#139523 date=1053269539]<br><br>Maybe we could start the equivalent of a tranny war on the additives to be used and to be avoided. ;D <br><br>AlpineRAM <br>[/quote]<br><br> > >
#47
Guest
Posts: n/a
"Actually almost all fuels are using additives on the base stuff to improve quality, or longevity of the fuel etc."<br><br>Here in my area, there is an outfit called "Pacific Pride", they operate cardlock stations for truckers and other users over quite an area out here in the west. Their diesel fuel is promoted as "Premium Diesel", and advertises that they add Power Service concentrate to the other components used by the base refiners - I contacted them to ask which PS product they used, and in what amount, they said it is a special concentrate - probably pretty much like the stuff off the shelf, and they add 1 gallon to every tanker load...
#48
[quote author=Monty(OkieBroncRider) link=board=8;threadid=14654;start=45#139527 date=1053269843]<br>[quote author=AlpineRAM link=board=8;threadid=14654;start=45#139523 date=1053269539]<br><br>Maybe we could start the equivalent of a tranny war on the additives to be used and to be avoided. ;D <br><br>AlpineRAM <br>[/quote]<br><br> > ><br>[/quote]<br><br>I was just kidding ;D <br>I think that this can be a very useful thread, but some people seem to get agitated easily. <br>Please do not take offence at my musings.<br><br>AlpineRAM
#50
Okie ;D<br><br>Another interesting thing I learned some time ago about pump timing was to use a cetane increaser to see whether timing was correct or not. If you had more power with a higher cetane number it was time to advance timing. This does not help on extremely long injection cycles, but for the average engine it helped to take a lot of guesswork out. <br><br>AlpineRAM
#51
Guest
Posts: n/a
"If you had more power with a higher cetane number it was time to advance timing."<br><br>HMMmm - I'm not too sharp on the finer points of diesel combustion - and the above seems directly opposite from that of a gas engine. In a gas engine, a higher octane (cetane in diesel fuel) was needed or useful if the timing or compression ratio was ALREADY too high - and if it was too LOW, increasing octane would NOT be beneficial...<br><br>Are diesels really that different in that regard?
#52
Gary: A common misunderstanding in octane and cetane numbers:
Octane tells you the resistance against being ignited by heat and pressure, cetane tells you the willingness to ignite by heat and pressure.
So if you have a higher cetane number the fuel will ignite earlier in the compression stroke. (If there is already some in the cylinder) a lower cetane number will retard the timing.
There is a difference in timing of the start of the injection and the timing of the burn.
AlpineRAM
AlpineRAM
#53
I remember reading somewhere that the gov't is trying to lower the sulphur content quite a bit more by 2007. I also remember reading somewhere that there was quite a surge of demand for new IPs after the last decrease, I guess it is sort of weeding out the additive users and non additive users. <br><br>I've always used Redline DFC (diesel fuel catalyst) in every tank of fuel ($35/gal, serves about 1200gallons) as it is an all in one additive. It lubes the IP, cleans injectors, reduces smoking, removes the same amount of water, a little antigel, and boosts cetane slightly. Almost does so much that it becomes unbelievable, in the winter I use two more additives.<br><br>Does anyone know what the lowest cetane a cummins should run on? I heard gravel trains and such run on 40, my MB requires 45, just wondering where the cummins comes in. Apparently pump cetane is normally around 42, super premium diesel is 50 cetane (different definitions of premium though).
#54
[quote author=BoostnBenz link=board=8;threadid=14654;start=45#140308 date=1053456961]<br>Does anyone know what the lowest cetane a cummins should run on? I heard gravel trains and such run on 40, my MB requires 45, just wondering where the cummins comes in. Apparently pump cetane is normally around 42, super premium diesel is 50 cetane (different definitions of premium though).<br>[/quote]<br><br>I have yet to see a Diesel pump with any numbers posted, asked once and the counter person had no idea what I was talking about.<br>There was a thread a while back, something about a petition to get stations to post Cetane like they do Octane numbers on the pumps.<br>I bet Cummins.com would have some numbers available for ours and other Cummins engines.<br><br><br>phox
#55
Location: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
1 Post
Best I remember, Cummins calls for a cetane of 42. If I can, I'll scan the fuel specs and post them tomorrow.<br><br>shortround out
#56
Here is a DFA that I am looking at. It is called Siloo. Anyone with any experience with it? A link about the product...Siloo. It claims to raise the cetane number by up to 8 points and is a lubricity/cleaner/booster product.<br><br>Not affiliated, just looking for input
#57
Guest
Posts: n/a
From what I've seen, you have to watch out for those claims of radical cetane increases... Either it's an outright lie, or else requires percentages of additive that is outrageous and expensive. In picking a fuel additive, you sorta need to define exactly what your basic priority is, lubricity? Cetane boost? Eliminating fuel jelling in cold weather? Injector cleaning?<br><br>Most additives seem to excell in some areas, and fall short in others - no particular problem there - warm climate users really don't NEED anti jelling, but can use the lubricity, etc...<br><br>Once you figure what you want MOST in an additive you can narrow your search considerably...
#58
As I stated in another thread, if you want higher cetane numbers and more lubricity you should look into adding a quite high percentage of biodiesel to your fuel. (about 5% at least)<br>Since the stuff is quite cheap (actually cheaper than standard over here) it does not increase fuel costs greatly per gallon treated. <br><br>AlpineRAM
#60
[quote author=4x4 link=board=8;threadid=14654;start=45#140952 date=1053617869]<br>Here is a DFA that I am looking at. It is called Siloo. Anyone with any experience with it? A link about the product...Siloo. It claims to raise the cetane number by up to 8 points and is a lubricity/cleaner/booster product.<br><br>Not affiliated, just looking for input<br>[/quote]<br><br>looks like and advertisement. it doesnt tell u anything about the product.
