INfo on Caterpillars
the 3116's were 7.2L weren't they? Like 442 ci?
the 3116 is 6 x 1.1L.. and the 3126 is 6 x 1.2L. that doesn't seem to work for the other engines like the 3208, 3406, 3408...???
I believe older Cat engines were easier to identify using the 3200,3300,3400,3500 and 3600 series designations. Some of these newer engines 3116, 3126, 3176, 3196, C7, C9, C10, C11, C12, C13, C15, C15 Acert and C16 are a little harder to identify sometimes.
Cat has many numbering structures...most times confusing.
There is the D342...available in the 35 ton quarry truck in the 60's or 70's
to the new 3516HD. High Displacement, Electronic injection, 4 turbos, v16 engine....16 individual heads, 4V per head....pushing a truck hauling 240 TONS of dirt on six 14 foot tall, 3 foot wide tires. I forget how many HP.....too many sometimes ;-)
Needless to say when one of them babies throws a rod, it usually creates a $200k boat anchor.
3406 c help?
I know the older 3406 a & b were mechanical foot pedal throttles, I have a "c" variant and the darned computer and reostat foot feed are fouling up, is it possible to bypass and go back to a manual/mechanical foot feed throttle. I keep getting a code (55 flashes) and tired of fighting to fix the problem, would going back to the mechanical pump and accessories resolve the problem?
we run 3516LE engines to right around the 100,000 hour mark before calling it done on the bottom end. Just finished up a 3520 ECOS top end overhaul today.. Running tons ofA-3's, ULB's, 36's, and GCM-CM34's....
The Cat engine identification system is strange sometimes. Some of it has to do with the era when the engine was originally designed. The 3500 series was never an OTR design, so it had different people assigning an identification to it vs. a 3208, 3116...etc.. they were initially designed as OTR engines... Still Cat, but different departments.
Dont forget C-18, C-27, C-32, C-175....
donhov
Oct 12, 2007 11:44 AM
donhov
Aug 16, 2006 11:42 PM
