Sponsored by:
Sponsored by: CARiD
I FINALLY got one.
Old Dec 31, 2006 | 09:21 AM
  #46
Got Smoke?'s Avatar
You don't always have to start out in first, its usually only recommended for when hauling a load. I am on my 2nd CTD (upgraded to club cab) and both had stock clutches when I purchased them, and both were fine starting out in 2nd all the time. Just doesn't seem reasonable to move 10 ft. then have to shift.
If your getting 18mpg then I doubt you will see any mpg gain with advanced timing. People mostly see a drastic improvement if the timing has slipped over the years. Example, my first CTD was a 97 Reg cab with 123K on when I got it, @ 140-odd K miles I had the timing done, and saw an improvement of 1.5 mpg immediately. However, the timing on the truck had slipped from the original 13.5* down to 11*, and we advanced it to 16*.
Your on the right track with the 3K GSK & fuel plate mods, and you will love them the first time you hook to a load. The first few times I hauled with my original CTD I was constantly shifting with a 5spd, 33" tires, & 3.55 gears.
Just make sure that the appropriate gauges (EGT & Boost) that you have already mentioned are installed before the fuel plate is adjusted. You have a very high fueling pump on that truck, and it won't take much to get EGT's up there with a load. Trust me I know!
Good luck and enjoy!
Old Dec 31, 2006 | 11:01 AM
  #47
TravisDj's Avatar
Well I am going to do all those mods even if not just to get better performance. I'm going to go back to stock size tires. I am hoping to see 20mpg. I think it is very possible. If not that is ok.
How big is the fuel tank on the 97?
Old Dec 31, 2006 | 11:24 AM
  #48
TRCM's Avatar
On the FP gage, I used a 0-60 psi boost gage, and a small needle valve. plumbed it all inline from the banjo bolt on the injection pump. I adjust the needle valve until the gage stops bouncing. About once very 6 months, I have to open and then close the valve.
I have, including the gage, tubing, and valve, less than 50 bucks in my FP gage setup.
Revy
Jun 16, 2005 09:51 PM
siotwo
14
Jun 4, 2005 09:00 PM
Begle1
Nov 30, 2004 04:34 AM
gottahavediesel
17
Oct 20, 2004 05:00 PM
danshsss
Nov 11, 2003 11:32 PM
