Good Golly
From: Drive till ya hit a Polar Bear, then go back 50 miles
Good Golly
http://performanceunlimited.com/illu...fulengine.html<br><br>
Wonder what kind of engine lift they use to move that sucker?<br><br>Rod
Re:Good Golly
I've seen the 40,000 - 50,000 hp versions of that engine on some of the newer container ships. Sutzer has been around a while and know how to build these engines. They use a small reduction to go from 100 rpm engine to about 75 rpm on the prop. The engine as you see from the pictures has no "transmission". These are direct drive. The engine is air start and will crank and run in either direction. So when a ship is maneuvering and needs to go from forward propulsion to astern, the engine is stopped and then cranked in reverse. Two cycle engines are nice in that respect.
Re:Good Golly
I just got off a APL ship the first of March.One engine B&W 66,383 HP. 3 turbos about 7 feet high. turns 104 RPM and the ship 900 feet long goes about 24 knots.
risner
30
Oct 13, 2006 04:44 PM
HOHN
Oct 14, 2005 07:31 PM
