Sponsored by:
Sponsored by: CARiD
fuel milage question
Old Sep 28, 2007 | 02:58 PM
TexMexCowboy's Avatar
I have read in a few other threads and they say that when i check my fuel milage i need to adjust for the bigger tires. Well i have 37's and when i hand calculate it says i get about 14mpg on the highway is that right or does it matter that i have bigger tires. what is on my sig is what i have on it. plus a boost fooler that i have not put on my sig yet.
Old Sep 29, 2007 | 08:28 PM
wreedCTD's Avatar
that is about right for 37s
Old Sep 29, 2007 | 11:07 PM
oh ok cool finally somebody answers thanks man
Old Sep 30, 2007 | 12:47 AM
HOHN's Avatar
When you hand calc you have to correct for the larger tires.
Is your speedo or odometer corrected for the larger tires? If not, then here's how to calculate:
(OEM tires revs per mile/37s revs per mile) times odometer mileage.
For example, your OEM tires might be 655 revs per mile. The 37s are probably around 560 revs per mile. So you take 655/560 and get 1.17.
So take your tripmeter reading at fillup, and add 17% (multiply by 1.17). If your tripmeter shows you got 350 miles on that tank, you actually had 410 miles.
In the above situation, if you calculated 14mpg, you're really getting 17% more, or 16.38mpg!
Nice change, eh?
Old Oct 1, 2007 | 12:19 AM
sweet that sounds very good. I am wanting to buy the Quadzilla "Max Mileage Module" and hoping to see results. But i am waiting to make my next trip home. Thanks I thought there was a way that i needed to do it. Next time i go home I am going to remeber that.
Old Oct 1, 2007 | 12:28 AM
annabelle's Avatar
http://www.1010tires.com/winter_tires.asp
Old Oct 1, 2007 | 06:28 AM
95dodgectd's Avatar
i would be happy with even 14 mpg's with 37s that pretty good still anything with a gas motor and those tires would be pulling 7mpg's or less probably.
ram 2500
Apr 30, 2008 09:11 AM
TravisP30
Feb 27, 2008 08:55 PM
Road Traveler
Nov 19, 2007 06:56 AM
Dually Driver
13
Nov 13, 2007 09:10 PM
Caspter
Nov 13, 2006 08:59 AM
