Sponsored by:
Sponsored by: CARiD
Electric blowers
Old Nov 3, 2005 | 08:59 AM
VADSLRAM's Avatar
Originally Posted by TAS05CTD610
I've never seen a dodge like that before...New model??
From the looks of it that is a Honda, problably stock (naturally asperated). That leaf blower problably puts out more air than that motor can take in, or put out, which is problably why it helped boost the HP on that motor.
Now that I think about it, I have to go put our leaf blower on my lawn mower and see how it'll do..... Hey even if it dosn't get more power, it'll blow the leave's outa the way.
And why where you digging around on a honda site???
Not a honda site, It's one of the best vehicle video sites out there. Lots of clips of drag racing diesels and stoooopid human tricks. A few babe shots too.
Old Nov 4, 2005 | 09:57 PM
Tree DR's Avatar
Found a web site that sells blowers not for this particular application. But I thought it might work. Anyone else have any thoughts? fanam.com
Old Nov 4, 2005 | 10:41 PM
Clunk's Avatar
Originally Posted by Tree DR
Will it hurt the tranny 1200rpm in 5th at 35mph for town driving? If you had no restrictions on a turbo like was mentioned wouldn't the exaust flow limit it some what? I'm not looking for top end or wot. Yes leaving the intake off is not a good idea. That's why I was wondering about some way to suck the air through the filter before the turbo to help with spool up as well as torque on the low end say up to 1800rpm. I'm looking for economy not 500 hp not that some version of this might not help. Like two big filters with 500cfm blowers on each? Can you get to much air in a diesel and reduce economy?
After you satisfy the oxygen needs of the fuel, all extra boost and compression is just additional work load on the motor.
Old Nov 5, 2005 | 01:44 AM
shawn085's Avatar
I thought I read somewere about a turbo that had an electric motor in it to help spool to get rid of some of the Lag. I think it was on a cat engine. Has anyone heard of this or tried it on a cummins?
Old Nov 5, 2005 | 03:21 AM
Jim Lane's Avatar
A lot of air..
If you are looking for some instant boost then all you need to do is connect one of these to a 5-hp.12 volt direct current motor or a hydraulic motor with a 12-volt power pack and accumulator.
Use a 3-way swing check valve so when the centrifugal blower starts it closes off the inlet to the air filter and spools up the turbocharger.
Hydraulic would be better because a 5 hp DC motor would draw around 100 amps @ L/R.
You could always stick a APU/ GPU in the bed and start it like a turbine.
Jim
http://www.horsepowerfreaks.com/buy/.../Superchargers
Old Nov 5, 2005 | 07:08 AM
Tree DR's Avatar
looking for economy not hp
The fan I found is AC and variable speed. www.fanam.com R series fan. Is there any way to monitor fuel economy onboard on a 97 Dodge diesel? If I could see what my MPG were doing instantly I could adjust the air flow to get the maximum economy as I drive. But I would have to be able to monitor instant MPG. I know the newer trucks have the computer doing it.
Diesel Girl
18
Oct 6, 2013 03:03 PM
cj5er
Dec 20, 2009 09:19 PM
1-5-3-6-2-4
ABDTR #5
Sep 22, 2009 09:27 PM
blackdiesel
Aug 28, 2006 03:58 PM
drecu
15
Mar 19, 2003 07:17 PM
