Small Block Chevy - blowers
Old Aug 26, 2006 | 05:19 PM
blackdiesel's Avatar
Registered
alright, school me. Ive got a 305 fuel injected throttle body in my 57. Came out of a 91 camaro. approx 35000 org miles. And im looking for more power. She just aint got enough to push this brick. So, what am i looking for and what would be the best set up for it??
engine swap is out of the question. i would kinda like a 454 tho
oh and what about the bigger throttle body?
Old Aug 26, 2006 | 05:23 PM
derek840378's Avatar
91 had the tpi 350. your best bet would ge a centrifugal supercharger. u would prolly need to upgrade the fuel pump, ecm and injectors. larger tb would definately be a good idea
Old Aug 26, 2006 | 05:25 PM
Registered
No, i have the throttle body 305. and why does the fuel pump, ecm, and injectors need to be replaced?
Old Aug 26, 2006 | 05:29 PM
more air, you will need more fuel. gas engines dont like to run lean like diesels
forget what i said about the tpi 350. forgot they had those. you could go w/ a roots blower w/ the other said mods
Old Aug 26, 2006 | 05:36 PM
Registered
well, changing the ecm aint gunna be a peice of cake. It has to be # specific to work with my wiring harness. surely possible, but where to get them and how much do they cost?
anybody else?
Old Aug 26, 2006 | 05:49 PM
anybody else?
oops. not the whole ecm needs to be changed, just the chip. they have custom chips in summit, starting @ 389.95
Originally Posted by Summit Parts Catalogue
Custom chips are necessary for vehicles with air intake, exhaust header, and cat-back upgrades, plus any of the following upgrades: turbo, cylinder heads, injectors, throttle body, supercharger, increased compression ratios over stock, cam changes, or other engine modifications, Each chip is specially made for your application-after speaking to a Summit sales rep, you will be contacted by a Motorvation technical representative to build your custom chip.
Old Aug 26, 2006 | 06:01 PM
Kemble's Avatar
You can get performance without having to go supercharged. You're best bet is to go to some camaro forums and look around there. I believe that engine is an L03 305. There are some very fast 305's out there that started out just like what you have there.
We rebuilt a totaled 92 rs camaro that had that identical engine. Later sold it to a local kid who now has it running in the high 13's with just bolt ons and a gear.
Old Aug 26, 2006 | 06:25 PM
Fronty Owner's Avatar
just bottle feed it and be done with it..
Old Aug 26, 2006 | 06:28 PM
dont forget to retard the timing 2* per 50 hp of spray
Old Aug 26, 2006 | 09:09 PM
BigBlue's Avatar
I suggest an 8-71 Weiand. That should get the job done.
Have you tried the usual stuff like cam/heads/gears/etc.? Blowers aren't exactly cheap and they can get expensive if you do a custom dyno tune (which IMO is 10000x better than a mail order tune). They are certaintly fun though. The biggest question is what do you want? Stupid low end response or more top end performance? For low end I suggest a roots style (Kenne Bell is my choice) cause they spin up really fast in the low rpm's and get the power now. For top end I recommend a Paxton or a Procharger. They do their boost on an almost 1:1 ratio with RPM so they dont come on as hard on the bottom end as a roots blower would but they excel on the top end charge after the roots falls off.
Why is everyone else on this thread rated as a good person and I'm an unknown quantity? Well look at that, 10,100 posts.
Old Aug 26, 2006 | 11:26 PM
Registered
i want the most power for little $$$ (obvisouly)
umm, this truck aint built to go fast, so ill take stupid low end performance.
i was thinkin a cam while i was at it. dont want to get too crazy tho. maybe 300-350 hp
Old Aug 26, 2006 | 11:42 PM
DmaxEter's Avatar
Most supercharger kits that I have seen for these fuel injected application are all inclusive. They will have everything needed to bolt on the blower and get you back on the road. Custom chip and all. At least the ones that I saw at the local speed shop did. I say a blower or custom turbo setup is just what you need. Some spray would be cheaper, but the blower is cool
Old Aug 26, 2006 | 11:47 PM
Registered
i dont want to have to fill up the bottle all the time! i just want to get in er and go.
Old Aug 27, 2006 | 12:03 AM
Kemble's Avatar
Check you're fuel pressure, That will make or break a tbi engine. The fuel pressure should be about 12-15 pounds for max performance using the stock ECU. These engines are notorious for not having enough and suffering top end HP losses.
What transmission do you have in the car? What is the rear end geared?
Another option would be trying to find a tbi 350 to drop in place of the 305. With just a chip change in the ECU everything will be ready to go.
Old Aug 27, 2006 | 08:39 AM
Registered
heh, well i stuck this fuel injected motor in my lifted 57 chevy truck. She's got a 4 in the floor with a 205 transfer case going to a dana 44 in the front and a full floater corperation 14 bolt in the rear with 3.73 gears.
