Sponsored by:
Sponsored by: CARiD
driveshaft question
Old Aug 22, 2010 | 10:55 PM
GCSS's Avatar
driveshaft question
one or two piece driveshaft ??
1998 Dodge 2500 extended cab shortbox 5 speed
I am taking a 1997 Dodge 2500 extended cab,long box 2wd cummins 5 speed and cutting the frame and putting on a short box. Just need to know if I just need a driveshaft from a 1998 quadcab will work or If I can shorten the 2 piecer I have
Old Aug 23, 2010 | 09:57 AM
infidel's Avatar
I would use a one piece driveshaft, way less problems.
The standard cabs came with one piece.
Not sure if the rear shaft on a two piece setup would be long enough or if you would need a new shaft.
Old Aug 23, 2010 | 11:08 AM
GCSS's Avatar
trying to figure what they came from the factory with....
Old Aug 23, 2010 | 02:01 PM
Sea:\>Drive's Avatar
Not sure in that year but my '01 QC SB 2WD is a one piece aluminum drive shaft.
Old Aug 23, 2010 | 02:19 PM
GCSS's Avatar
OK....cool.
what is your wheelbase????????
Old Aug 23, 2010 | 06:41 PM
infidel's Avatar
It has to be aftermarket.
Only the standard cabs came with a one piece until about '07.
Old Aug 23, 2010 | 06:48 PM
hotdram's Avatar
My 02 Q/C SB had a one piece from the factory. I turned it into 2 while towing
RJohnson's 02 Q/C LB has a two piece from the factory.
~Rob
Old Aug 24, 2010 | 09:46 AM
FarmerJim's Avatar
My 03 QC SB came with one piece driveshaft from factory also.
woodrat
Jan 9, 2007 06:49 PM
signature600
Sep 18, 2005 02:18 PM
98 2500
Feb 17, 2005 02:00 PM
