DIY Jumper Cables
DIY Jumper Cables
I know many of you make your own jumper cables, and I was thinking about doing the same(after we melted a "heavy duty"
by jumping a huge onan generater with the CTD ) ..So I wanted to know how many of you would like to share your design for a Heavy Duty set of Home made jumper cables..
Thanx in advanced,
Mike
by jumping a huge onan generater with the CTD ) ..So I wanted to know how many of you would like to share your design for a Heavy Duty set of Home made jumper cables..Thanx in advanced,
Mike
Very few of the consumer "heavy duty" cables have anything more than a heavy duty amount of vinyl insulation around some pitiful gauge copper wire.
I recently bought a NAPA boxed set for my CTD that was pretty heavy duty..
The quick test to see how heavy duty they are is by sheer weight.. More weight=more copper. The NAPA set passed the test.
BUT,...If you still want to hand-make some SERIOUS jumper cables, go down to the welding supply company and purchase some welding cable. Number 2 or larger cable(like 2/0) and find some big Mueller brand solid copper alligator clamps with matching red/black rubber sleeve covers. Dunno if welding supply will carry Mueller alligator clamps but some electric/electronics supply houses carry them. You'll have to use two hands to pick that set up! It'll take two hands to work each clamp too! This is not a set for your wife to be pressed into using on a rainy night.
BTW, these quality hand-made jumper cables tend to sprout legs VERY readily... I know... mine did!
FYI, NAPA also sells a semi-permanent version similar to what I bought and it comes complete with two pole Andersen quick disconnects that eliminates fooling around with battery clamps on your truck end. This also eliminates the lowlife brother-in-law from permanently "borrowing" them as he won't have the mating connector!
Good luck...
Keith
Good luck...
Keith
go to you local electrical supply house and ask for some 1000 kcmil wire with a 90C temperature rating... that is good for about 700 Amps continuous. Ok, so it has a diameter of 1 1/2".
I've got a set of military surplus cables.
They're ~2 gauge stranded, long enough that I can park behind a vehicle I'm jump starting and still reach the other car's battery.
And they weigh about 10 pounds.
Mine are 35 feet X 2 of #2 welding cable with copper lugs crimped onto the ends. Then bolt the 500 amp parrot clamps to the end of the cables.
I also have a 35 foot pair with anderson connector that connects to a mating anderson under the hood.
jumpers
Don't you lose some "juice" with the real long cables ? I would be worried that I wasn't getting enough power at the other end. I got some pretty heavy duty cables from NAPA and they hold up great.
PISTOL
PISTOL
