Sponsored by:
Sponsored by: CARiD
Diesel Fuel Additives
Old Jul 3, 2003 | 02:20 AM
DarrellB's Avatar
There has been a lot of talk lately on Diesel Fuel Additives (DFA's), so I did a bit of searching and found some info that my be useful to everyone. Every manufacturer claims their's is the best DFA but I myself like to make my own decisions. Dodge and Cummins tells us that we do not need DFA's but with the tight tolerances of the VP-44 on the 24valve engines and the poor quality of fuel these days I would seriously think about using some sort of DFA. I hope this info will be a help to others like it has been to me.
Read in good health.
Amsoil Additives
Fuel Additive Concentrate
Diesel Fuel Modifier
Centane Boost
Power Service Additives
Diesel Kleen
Stanadyne Additives
Performance Formula
Shell Rotella Additive
Rotella DFA
Old Jul 3, 2003 | 05:22 AM
Dalton Gang's Avatar
Re:Diesel Fuel Additives
How about used oil. 15-40?? ;D ;D
Old Jul 3, 2003 | 07:50 AM
Dieseldude4x4's Avatar
You'da man DB. 8) 8) 8) 8)
I buy five quarts of Powerservice at a time. I use half a quart every fill up for four quarts then dump a full quart in on fill up number nine. May be more expensive but I don't look at just the price. (and it's my truck too)
Old Jul 3, 2003 | 08:21 AM
TXRAM2's Avatar
Please correct me if I'm wrong, but doesn't PS stuff contain alcohol. ???If so, is that a good thing or no ???<br>I have been using the Stanadyne Performance Formula, but thinking of using their lubricity formula next, since it is mainly lubricity that I am interested in.<br>
Old Jul 3, 2003 | 10:48 AM
redramnc's Avatar
I just pulled 26.45 mpg out of 45 cetane Premium Diesel and about 10 ounces of Diesel Kleen. Since I started using Diesel Kleen on every fillup I have seen about a 1 mpg increase and that is in everyday driving with 50 miles of 70+ mph commute everyday. Your results may vary ;D
Old Jul 3, 2003 | 11:56 AM
TXRAM2's Avatar
Gary, that is exactly the type of opinion I was lookin for. 8) I have often used the PS ( with mixed emotions about) and what you said makes sense to me, thanks ;D
Old Jul 3, 2003 | 12:04 PM
redramnc's Avatar
At 400:1 ratio of diesel to PS the alcohol content is negligble. I run about a tank per week - 10 days so there ain't a whole lot of time for what little bit of alcohol there is to soak up moisture. I figure the added lubricity and detergents take care of any miniscule amount of water that might be attracted by the Diesel Kleen. Never any signs of water in the fuel seperator so it it must not be a big deal.
Old Jul 3, 2003 | 04:27 PM
SjLingenfelter's Avatar
I have a quart of PS DieselKleen. What do yall recommend other than PS? Should I put the whole quart in? Its gonna take about tank and a quarter to get to the ranch.Should I just put the whole thing in or half now and half after I fuel up again? BTW its a 44 gallon tank. <br>Thanks<br>SD03
Hoss's Avatar
Thats MR Hoss to you buddy!
So do you guys put this stuff in at every fill up or what??
Old Jul 3, 2003 | 04:34 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I've been adding a 2.5oz bottle of this every tank since April.
About $2.50 per 2.5 oz bottle, but refilling the bottle from a gallon jug cost $.83 per tank. ;D
In the winter I use about 6-8 oz of Howes Diesel Treat every tank.
Old Jul 3, 2003 | 04:52 PM
Pete Peterson's Avatar
Most of the additives do perform a service for us and anyone of them is better than nothing.<br><br>Don't know about the others but I put it in every time I fill up.<br>It lubricates the pump and that is important enough to me to use it all the time,, Regards.....Pete
Old Jul 3, 2003 | 05:33 PM
DarrellB's Avatar
One other small thing you may want to remember is to always make sure you add the DFA's when filling up the tank. If added onto the top of the fuel the DFA will not get mixed propper. <br><br>I've used both the Power Service and the Rotella DFA they both seem about the same to me as far as millage gains, the only difference that I can see is the Rotella DFA seems to make the truck smoke a little less than the PS.<br><br>I'm going to try some Lucas DFA this time and see how it does.<br><br>DB
