Sponsored by:
Sponsored by: CARiD
?? diesel addicted to starting fluid
Old Mar 13, 2006 | 08:52 AM
Dan Marino's Avatar
I just bought a couple of timberjack skidders (with cummins) as a two for one. Both of them are 'addicted' to starting fluid. My question is what makes them addicted and is there a way to break them. Background of the two- 1994 models, both have been rebuilt with around 2600 hours on them now. The motors are very strong / one smokes white off and on during idle and pulling.
Old Mar 13, 2006 | 08:59 AM
05mxdiesel's Avatar
I went through the same thing with a PSD. The first thing you need to look at is the grid heaters. If the grid heaters are not working the addiction cannot be broken until they are fixed.
Old Mar 13, 2006 | 09:37 AM
DetroitDiesel71's Avatar
From: Dayton, NJ (temporarily while In USCG on Staten Island)
Ether dependency is the result of continuous starting fluid shots. The top compression ring becomes mis shapped from the continuous shots of the stuff and volatile temps. So in time your compression weakens to a point where it needs that shot to start it up. The engines will usually become dogs and smoke until rebuilt. Hope that helps a bit.
Stephen
Old Mar 13, 2006 | 09:44 AM
Dan Marino's Avatar
Detroit
Both are not dogs yet. But I am getting ready to pull one motor to put a rear main in it and also turn the bearings and valve work. While it is out can the fix (for the ether) be done without a major rebuild.
Old Mar 13, 2006 | 09:50 AM
BearKiller's Avatar
Ether, used with discretion, will do no harm.
The trouble is the wooden-heads that grab a can and drown the intake until it drips.
No harm will result from just a breath of ether while the engine is cranking.
As previously stated, you may have to re-ring to "wean" the engines; but, if they start and run satisfactorily, I would simply ether them until an over-haul was necessary, then address the problem.
fourthandgoal
19
Jun 28, 2010 11:17 PM
jbworm20
33
Aug 28, 2007 05:31 PM
vzdude
Jul 4, 2007 09:53 PM
getblown5.9
Aug 21, 2006 01:23 PM
Common
Aug 20, 2006 05:47 PM
