Sponsored by:
Sponsored by: CARiD
Cummins B 6.7ltr Info
Old Jul 24, 2004 | 12:38 AM
dodgeman01's Avatar
a long time ago I said some stuff about a new 6.7ltr cummins and nobody believed me sometimes I'm so smart it hurts
DM01
Old Jul 26, 2004 | 12:57 AM
HOHN's Avatar
I hear you, Don. It seems everyone is going with the "just enough to get it done" level of strength on internals.
I'm surprised the screws are threaded all the way! I'm curious as to what ARP discovers. Looks like the Hi HP guys might need a little bottom end beef-up on the newer trucks.
Of course, there's always the Oliver/Crower/Manley option...
jlh
Old Sep 9, 2004 | 10:05 AM
HOHN's Avatar
TTT
Don, any update on capscrew strength from ARP??
Old Sep 9, 2004 | 05:19 PM
Monty's Avatar
Mercedes Benz also runs the fracture split design on there 6ltr and 12ltr engines. The way I was told is that with a fracture design, since you are forging out of the same metal for the cap and rod, the expansion rate will relatively stay the same. If you take a conventional rod and cap and a dial bore gauge and measure the 4 points. You will find that the bore is actually egg shaped somewhat. Fracture split design alleviates this since it is forged out of one piece. So, the 4 points are the same. This is also allowing manufacturers to build an engine with less oil clearance.
Old Oct 4, 2004 | 03:52 PM
HOHN's Avatar
Don, any update on the screws from ARP? What did they find?
jlh
Old Sep 23, 2005 | 02:18 PM
HOHN's Avatar
TTT-- any update on the capscrew test results from ARP??
Old Sep 29, 2005 | 11:33 AM
Don M's Avatar
DTR Advertiser
Its only been a year! LOL
The stock CR rods and fasteners are just fine for what we need at this time.
Don~
Old Sep 29, 2005 | 01:16 PM
johnny1509's Avatar
I've been telling my wife for 10 years that my rod is 7 inches......
Old Sep 29, 2005 | 02:24 PM
CTD NUT's Avatar
......oooo, the Admins won't like you....
Old Sep 29, 2005 | 10:11 PM
DR3500's Avatar
Originally Posted by Monty
the gear train is arranged in the back like the 3rd gen engines and the 6.7ltr engine does not use the AFC head VE, only the 4.5ltr.
I have been led to believe there are 2 versions of the 24 valve 5.9, the QSB which has the rear cam drivetrain and the ISBe that is used in the 3rd. gens and have the front cam drivetrain. The QSB is the industrial/agricultural version. they are the same other than cam drive orientation.
Old Sep 29, 2005 | 10:28 PM
cumminsdriver635's Avatar
They probably use the VE because it can mechanically advance the timing as the rpm's increase(i think), where the p-7100 cant.
Eric
donhov
Oct 12, 2007 11:44 AM
2rowdy
Oct 1, 2007 03:31 PM
tboling
Apr 9, 2007 09:04 PM
ProjectM880
Dec 1, 2004 06:40 PM
