Cummins 5.9L in F750 and other MDT trucks
i have a 97 fl60 and it is rated at 210 hp also.and i will agree on the allison.only reason i got it is my girlfriend didn't want to drive another stick,every vehicle i have is a stick.
I don't know about the Cummins, but a lot of marine engines use raw water (lake or sea water) to cool the exhaust manifold, turbo, charge air cooler, and engine. Usually, there is a water-coolant heat exchanger for the engine. They don't run raw water through the engine.
But you not relying on a fan cooled radiator which helps with the added HP.
You can have the shift points adjusted. A friend of mine and me made my 545 manual shift so when I put the shifter it 3rd it is in 3rd and when I put it in 4th it is in 4th. You can also change how hard it shifts into and out of each gear. I have it in a 92 Dodge 1st Gen 4x4.
Shaders 24v
Apr 25, 2004 10:43 PM
