Sponsored by:
Sponsored by: CARiD
Anti sieze or not, that is the question?
Old Nov 20, 2007 | 10:46 AM
GreyTD's Avatar
when changing ball joints, u joints and other metal to metal parts, do you use anti seize on them or not? which parts do you use anti seize on?
Old Nov 20, 2007 | 11:29 AM
Spooler's Avatar
Nope, I never do because I don't want them moving around or even thinking about it.
Old Nov 20, 2007 | 12:09 PM
fiveology's Avatar
Only time I use anti-seize is when two dissimilar metals will be in contact (example, a stainless steel bolt going into an aluminum bracket), or when specifically called for in the installation instructions.
Old Nov 20, 2007 | 12:21 PM
JD730's Avatar
We only use anti-seize on threads and and anything with a loose fit that has to come apart or move.
On press fits like ball joints and u-joints we usually hit them with some light oil to help them go together easier. Anti-seize is a waste here because the press fit wipes it off.
Old Nov 20, 2007 | 04:11 PM
phabib's Avatar
I use it on exhaust bolts.
Old Nov 20, 2007 | 04:19 PM
JKM's Avatar
JKM
the only place i have used it on my truck is on the back side of the wheel bearing assembly , so it comes out easier next time.
Lyall
Sep 7, 2006 06:38 AM
RonP
Jul 12, 2006 12:30 PM
mitchkim
26
May 28, 2005 07:30 PM
DEC
24
Dec 19, 2003 07:13 PM
BADodge2003
Aug 24, 2003 07:22 PM
