Sponsored by:
Sponsored by: CARiD
Another weight question
Old Mar 9, 2005 | 10:38 PM
wgingg's Avatar
[QUOTE]Originally posted by rjohnson
[B]Question - The axles are the same on the Third Gen 2500 & 3500?? On 2nd Gen trucks they are very different! Dana 70 vs Dana 80 in the rear.
my 2500 second gen came with dana 80
Old Mar 10, 2005 | 08:59 AM
BarryG's Avatar
If I recall correctly the 2nd gen 2500 auto came with the rear 70 and the manual trans came with the 80 but both have the same front 60. The 3500's same front 60 and both the manual and auto came with the same 80. I may be wrong going from my ever failing memory.
Old Mar 10, 2005 | 11:22 AM
tool's Avatar
If you go buy the D.C ratings my truck has a similar Payload to my old F150
yeah right..............
Old Mar 12, 2005 | 08:21 PM
Patrick Campbell's Avatar
Re: Another weight question
Originally posted by Strick
Ok here is the question.................
Dodge says My truck has a 9K GVWR
They say My truck weighs 6800
They say my paylaod is 2200
and finally that my truck has 5200/6010 GAWR
Which number should I really be worried about staying within? I am not talking "legally". If you look at those numbers they are not consistant. If I were a NFL lineman and had 3 of my line team mates in the truck with me and had a fifth wheel hooked up the maximum pin weight, or the maximum payload that I could haul could only be about 600lbs. That is if you go off the GVWR. It just seems to me that if you stay with in the GAWR you still would be fine.
I am sure this has been answered but I could not find the exact answer. I am looking to get a toy hauler with a pin weight of 1700 or 2100 lbs and am strugling with numbers.
Strick, check out my site - http://xj.cdevco.net/auto/dodgetowing/. The number that you need to worry about is your TIRE rating. Your tires are rated to 3145 per tire @ 80 PSI approx. So double that you get 6290. Now subtract the rear curb weight of the vehicle, probably about 3000 max. Leaves you 6290 - 3000# = 3290# of pin weight before you reach those limits. You are well witin your safety range. Don't forget a good brake controller and to inflate tires to 80 PSI.
FWIW rear axle limits are ridiculously underrated on our trucks, they are based on the tire ratings basically. The front axles are pretty close...
http://xj.cdevco.net/auto/pdfs/dana_axle_ratings.pdf
http://www.aam.com/
Old Mar 12, 2005 | 11:42 PM
Haulin_in_Dixie's Avatar
You forget what you are dealing with when it comes to the legal setup of the factories. For EPA and insurance purposes, they sell a 2500 as a 3/4 ton truck, that means the capability to haul 1500 pounds. The same for the one ton at 2000 pounds. When you are pulling a goosneck or fifth wheel the GVW goes out the window and is replaced by the GVCWR. Dot figures this by one of two systems depending on the state. Federal and some states is the GVW of the truck plus the weight of the trailer and any load theron. Other states have it as the GVW of the truck added to the GVW of the trailer. But then if you are plated for the weight that you are hauling, the state has given you license to haul the capacity of the plates and the only restriction is the capacity of the tires and the axles. They never check the axle capacity just the tires.
And yes, if you hit a school bus full of kids and kill a few, all bets are off and the prosecution will look for any way to get you illegal. The second gen handles mid thirtys with the stock suspension at 7000 pound rear axle weights with ease. I don't overload tires though, I like to live. I have had mine loaded to 6100 front, 7500 rear, with no problems.
On a DOT check, the inspector twice has taken all the info and when reading the 8800 pound GVW on mine while weighting 30,000, made some derogatory comment, but no citation or DOT gig on it. So far as will it take it, my 2500 is approching 300,000 while pulling the same trailer at these weights. Original bearings on all wheels, none loose. Did lose a carrier bearing, but replaced it and the rear is doing fine. Same for U joints and center bearing. It has had three sets of brakes on it. The mileage is 323k. Of course I baby it, never run much over 75...
Old Mar 13, 2005 | 08:01 AM
RowJ's Avatar
H.I.D.
Great "Real World" info!
RJ
Old Mar 13, 2005 | 12:07 PM
Originally posted by 59FORD
I gotta throw in my 2 yen on this subject.
I pull a 53 ft car hauler with a 67 ft total length, tip the scales at 14,400 EMPTY
and as high as 36,000 LOADED. with a 1st gen 5.9 in my ForCum.
Most DOT cops will fall back to the tire rating in an overweight "condition"
Oooppps that was 3 1/2 yen...... sorry!
One day when they are in a bad mood, either Tennessee or Florida will get you for overlength. If I remember right you have a flatbed on the truck. A pickup bed or flatbed makes your truck a "truck & trailer" These go by individual state laws instead of the federal minimum of 53 foot and any length tractor. That is why I have no bed on the truck and have it registered as a tractor in stead of a pickup. Unless Tennessee has gone for longer lengths lately, Florida is still short on truck and trailer. Yep it is done every day, but just something they can get you for if they want. I went with a friend and paid a Florida overlength citation, Tennessee has never put a tape on one that I have been in. Alabama has a 57 foot trailer length, love it. A car hauler here can go 75 feet long.
Another little tip that I learned the hard way, if you do run 14 ply rating tires with the 110 pound pressure in them, put the brass bolt in valve stems in the rims. The rubber stems will blow out. Been there.
John Marshe
Aug 14, 2020 09:00 PM
Purplezr2
Jul 25, 2011 04:31 PM
Alaska Sunrise
Aug 17, 2010 02:09 PM
Mark Hodowanec
Apr 28, 2007 02:22 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
