Sponsored by:
Sponsored by: CARiD
aluminum heads
Old Apr 20, 2003 | 04:52 PM
Striper's Avatar
aluminum heads
Does anyone know when Cummins started using aluminum heads? I noticed the 03's have them but haven't been able to check out earlier years. Thanks.
Old Apr 20, 2003 | 06:01 PM
Dieselbuilder's Avatar
Re:aluminum heads
HEVER 03 are cast
Old Apr 20, 2003 | 06:03 PM
tmiller24's Avatar
Re:aluminum heads
I'd think you must've gotten the only one. :P I'd bet that the '03 models must be IT! Tony
Old Apr 20, 2003 | 06:17 PM
DPG's Avatar
DPG
Re:aluminum heads
As far as I know, Cummins has never used aluminium heads. Any of you guys hear of that? Monty? Anybody?
Old Apr 20, 2003 | 06:53 PM
spots's Avatar
Re:aluminum heads
OOOOHHHHH now you've done it.........Aluminum heads on a Cummin(g)s......Only because F*rd owns Cummin(g)s... . Check out them HEUI injectors too
Old Apr 21, 2003 | 11:32 AM
97CTD's Avatar
Re:aluminum heads
Cummins does NOT use aluminum heads Actually in our case it would be Head not heads! ;D ;D
Old Apr 22, 2003 | 05:15 PM
OH  Sick's Avatar
Re:aluminum heads
aluminum heads WHO IN THE WORLD STATRED THAT?<br><br>Oh Sick
Old Apr 22, 2003 | 06:49 PM
scottrod's Avatar
Re:aluminum heads
Dodge has probably quit painting the engines now also :-[
so maybe it's cast iron without paint and looks like aluminum? ???
Seems it's VERY expensive for DC to paint driveshafts, frame rails etc... :
Old Apr 22, 2003 | 07:32 PM
Monty's Avatar
Re:aluminum heads
Cummins does not make any engine in there lineup with aluminum heads. For that matter, I have never seen a Cummins engine with aluminum heads, from the B series, C series, ISM, ISL, ISX, BC series,VT903, KTA's, all NTC models for that matter.
Old Apr 25, 2003 | 11:33 PM
atoughram's Avatar
Re:aluminum heads
Are their any pro's to using aluminum heads?? In a gasoline motor, one can bump up the compression because aluminum heads tend to detonate less, but thats not a pro for a diesel. In a gasoline motor, aluminum heads get the heat away from the combustion chamber quicker, but thats not a pro for a diesel.... What are the pro's?? Head Gasket change outs more often??<br><br>Dont the new 6.0 Powerjokes have AL heads?
Old Apr 26, 2003 | 04:59 PM
EricBu12's Avatar
Re:aluminum heads
Cummins does a clear coat on the engines. At least they do in IN. I was there at the nationals
Old Apr 26, 2003 | 08:34 PM
Stamey's Avatar
Re:aluminum heads
The 2003 heads are cast iron. There is a riser between the head and the valve cover and that may be what people are looking at, assuming it is the head.
See pic:
Chris
Old Apr 27, 2003 | 01:23 AM
Striper's Avatar
Re:aluminum heads
It was the riser that I had noticed at first glance. My apologies if I upset anyone thinking that a CTD would actually have an aluminum head. What the hell was I thinking?
coolbreeze
16
Dec 16, 2007 11:37 PM
saltydog
Jul 30, 2007 06:25 PM
cumminsho2500
Sep 9, 2003 02:56 PM
DarrellB
Nov 25, 2002 09:49 PM
chuck3
Oct 20, 2002 12:19 PM
