Sponsored by:
Sponsored by: CARiD
Air bag pressure
Old Jun 20, 2011 | 01:15 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
5 to 10 PSI here, empty. Over time they seem to pump up somehow.
10 takes the harshness out of the bumps
Old Jun 26, 2011 | 02:08 PM
CLICKBANGBANG's Avatar
I tow nearly every day for work. I just leave 35 lbs in them (unloaded) and when bumper pulling a heavy trailer, it ups the pressure to 45 when you hook the trailer up.
If I was to not tow all the time, I'd leave 10 lbs in them.
Old Jun 29, 2011 | 04:50 PM
dodgepower88's Avatar
With my firestones i keep about 8 psi when empty, and just recently pulled a load with 60 psi. To be honest I don't know if they help much empty, but when loaded up they work as advertised.
Old Jun 29, 2011 | 05:15 PM
dieselfreak21's Avatar
mine won't hold air more than a day or 2 i run them empty all the time for 130k miles. Still work great. (they leaked from day one in the fittings). Depending on load determine air pressure. I bring the truck back up to level and if the front is still floaty I give it more in 5 lbs increments.
Old Jun 29, 2011 | 07:05 PM
AH64ID's Avatar
I keep mine at 5-7# with an empty truck. I check them in the morning so they usually have more pressure in the afternoon.
As for when loaded I put enough air in them to let the suspension compress about 1-1.5" so the thick leaf in the pack has a bigger role in supporting the load.
Old Jun 29, 2011 | 10:35 PM
whiteeye42's Avatar
thanks for all the replys right now i have 10psi in the bags and that seems to be working for now in a few weeks when i load up the fifth wheel and air the bags up then we will see how everything works and feels
Old Jun 30, 2011 | 12:08 AM
03 ant a hemi's Avatar
I run mine around 20psi empty and 65 with my truck camper in the back.
Old Jul 22, 2011 | 07:50 AM
Don T's Avatar
I run 10lbs empty and with pin weight of 1191 lbs I run 28 lbs. I have the Firestone air bags with the compressor so changing air pressure is a snap.they are set at 10 psi and as soon as I start the truck the compressor will top them off at 10 psi. I have removed my helper springs and they are not going back on.These air bags are awesome.I can level my fiver for towing and have used them to lift a fiver with tow straps . The guy got two tires off the side in a ditch at the campground and I was able to lift the bumper off the shoulder and tow him out. Bowtie duale lol was a happy guy.
Old Jul 22, 2011 | 03:11 PM
Iron Mike's Avatar
I have the Firestone's. Firestone says to run minimum of 5 PSI. I don't have onboard air so I keep mine at 25. It still rides good and it takes a pretty good load to make it squat.
Old Jul 22, 2011 | 07:21 PM
whiskers's Avatar
I run 5psi empty with my Firestones. and about 25 to 30 when hauling my 5th wheel.
Old Jul 26, 2011 | 08:55 AM
AH64ID's Avatar
Holy cow thats a lot of empty air! My ride is 10x worse when I leave that much air in them!
Old Jan 3, 2019 | 09:08 PM
Devon Donte's Avatar
0 psi is horrible on airbags
Originally Posted by klx650a2
When empty, I run 0 psi. Even 5 psi gives me a choppy ride when completely empty.
the air bags are not designed to run employ regardless how little off roading or highway driving you do. The rubber not having any tension pushing walls out will rub together on inside you won’t ever see it until they thin and pop when pumping some time. Also they can fold over punch and puncture. FYI do as please obviously you paid for them and own them but have yet to find maker or bags you warrenties or supports 0psi when no load. With 5-8psi there is little to no difference in ride not loaded very worth doing to have bags last for years to come and dependable each time I need to use them
Old May 2, 2019 | 05:02 AM
Jim Lane's Avatar
I have Firestone airbags on my 1st Gen and I run between 35 - 40 psi in mine, but I also removed 1 leaf from my spring pack that lowered my spring rate by 800 lbs.
I was told with the particular airbag I have that every 1psi = 50 lb spring rate.
Also it is not good to run them empty, they can get folded in on themselves and damage the sidewalls causing a leak.
Keep at least 5-psi when they are empty.
I have ok been under trucks when the bag explodes, they are dangerous.
Jim
Old May 5, 2019 | 12:16 PM
SIXSLUG's Avatar
I keep mine puffed to where they aren't folded over to avoid them rubbing out from road debris. 30 psi and it's like riding a rock....
Lonepine78
Sep 25, 2013 10:57 AM
herb
Jul 18, 2008 08:25 AM
DODGE4X4
Jun 16, 2007 07:27 PM
PZM123
Feb 5, 2007 06:01 PM
fitzer
Aug 12, 2003 11:07 AM
