96,000 mile service?
the dealer sent me a notice that i am due for my 96,000 mile service. i am curious as to what that is, as 96,000 is an odd number as oppossed to 100,000.
anybody know what this service includes?
thanks.
bought the truck used had no owners manual.
thanks.
Probably involves you bent over with no lube
Other then mabye a tranny and radiator service there's nothing to do other then look over it real good, nothing another shop can't do for probably alot less.
Wow! that was really helpful 01-24V......
Being you bought the truck used and have no service history, it's pretty much up to you to determine what is needed. How long have you owned it, what have you done/had done? List some of those things here and we can point out things that can be looked at. Luckily when I bought mine used the guy who had it bought it and had it serviced where I work. If I had no history to go by, I generally hit hard and do everything that is required up to that mileage. On the dodge list the big services on that year are actually 30-60-90K.
Here's what the good book calls for at 90k....
90000 MI or 144000 KM
Adjust
Band, A/T Notes
Drum Brake System Notes
Adjust rear brakes.
Clean
Crankcase Filter Notes
Service (drain) the crankcase breather bottle.
Inspect
Brake Hose/Line Notes
Brake Pad Notes
Brake Shoe Notes
Cooling System Notes
Check engine coolant level, hoses, and clamps.
Drive Belt Notes
Replace as necessary.
Exhaust System Notes
Fan Clutch Notes
Harmonic Balancer - Crankshaft Pulley Notes
Water Pump Notes
Inspect water pump weep hole for blockage.
Wheel Bearing Notes
Inspect front wheel bearings. Clean and repack, if necessary.
Lubricate
Steering Notes
Lubricate steering linkage.
Replace
Engine Oil Notes
Fluid - A/T Notes
Fluid - Differential Notes
Change front and rear axle fluid.
Fluid - Transfer Case Notes
Fluid Filter - A/T Notes
Fuel Filter Notes
Replace fuel filter element. Clean the water in fuel sensor.
Oil Filter, Engine Notes
Rotate
Tires
.....and 97.5K
97500 MI or 156000 KM
Adjust
Adjust rear brakes.
Clean
Flush
Coolant Notes
Flush and replace engine coolant.
Inspect
Lubricate
Steering Notes
Replace
Engine Oil Notes
Fuel Filter Notes
Rotate
Tires Notes
Adjust
Band, A/T Notes
Adjust rear brakes.
Clean
Inspect
Brake Pad Notes
Brake Shoe Notes
Drive Belt Notes
Fan Clutch Notes
Water Pump Notes
Wheel Bearing Notes
Lubricate
Steering Notes
Replace
Engine Oil Notes
Fluid - A/T Notes
Fuel Filter Notes
Rotate
Tires
.....and 97.5K
Adjust
Adjust rear brakes.
Clean
Flush
Coolant Notes
Inspect
Lubricate
Steering Notes
Replace
Engine Oil Notes
Fuel Filter Notes
Rotate
Tires Notes
That's the dealers way of getting you into his service shop. Since I have had my '03, the dealer as sent me a 14000 mile, 43000 mile, 49000 mile, and 52000 mile, and 57000 mile service reminder. Ain't no such thing. Their service reminders are as technically proficient as most of their service
kenni
62
Mar 11, 2012 08:46 AM
finndogg54
21
Aug 20, 2007 07:01 PM
SOhappy
34
Mar 4, 2006 04:16 AM
