Sponsored by:
Sponsored by: CARiD
700hp / 1700ft in NC
Old Jan 4, 2007 | 01:38 AM
BigBlue's Avatar
My first question is does goerends even build a 5 disk converter? Secondly, those are definately the BD twins and while I've seen them cool 600hp with water/meth I highly doubt that they are doing it at 700. Especially at 85psi. I think BD recommends no higher than 65? I say go and drive it. With that kinda power you should be able to keep those tires boiling smoke up to at least 70mph from a standing start with no boosted launch. With a boosted launch I'd be surprised if they ever caught.
Old Jan 4, 2007 | 06:43 AM
dieselfan's Avatar
that is dtr member Storx 's truck, in his sig he claims 591hp with some custom bd twins and jammer stage 5's.
i use to send him pm's to ask questions about his setup and he would never answer them. this made me think he was lying about his setup and now he really is. hes the one that claims to have rebuilt his tranny 5 times or so by himself and said it was easy.
he was also the one that started that thread: how much performance is to much????here is the thread https://www.dieseltruckresource.com/...ighlight=storx
and everyone got super mad at him. check his sig out.
Old Jan 4, 2007 | 07:20 AM
John_P's Avatar
Man you guys had me going with those numbers,.......700 H.P./1700 ft.lb. of torque! Heck,...my old 96' only put down 1383 torque and that was at 75lbs. of boost.
John_P
Old Jan 4, 2007 | 09:22 AM
COUNTRYBOY's Avatar
OMG!!! I know that truck!!! The guy used to be stationed here at MCAS Cherry Point, might still be, I just haven't seen the truck... Let me start by saying those are BD twins and the #'s are waayyyyy off... that thing has been rode hard and put up wet!!! He used to run it up at the New Bern 1/8 mile strip on the weekends... His roomate or buddy was at the auto hobby shop when I was installing my SPS 62 and he said that his buddies truck ran 115 pounds of boost and bla, bla, bla. I told him that even if those little BD twins could handle that much boost they would be major heat pumps. He gave me a thousand yard stare... He came back with drag cars run that much, I was busy, so I said you have some home work to do if that's what you think...
Old Jan 4, 2007 | 04:41 PM
dieselfan's Avatar
here is his sig storx
2000 Dodge Ram 2500 Long Bed Single Cab
*Custom BD TWINS*ATS HEADERS*F.A.S.S system*EGT/FP/Boost/Tranny Gauges*275 Injectors "Stage 5 nozzles"*Custom Tranny/Filter System "goerend Triple Disk"*Transgo Race Only Shifter Kit*Edge Drag Pro Comp stacked W/ Smarty*6" Stacks/3 Stage Exhaust Brake*ARP HEAD STUDS*Fire Ringed head*2 stage water/meth*
*Dyno 4/11/06*
576HP/1,302tq 3 PULLS
591hp/1,583tq 1 PULL
1/8th 8.45@98mph
1/4 12.85@112mph
Old Jan 4, 2007 | 04:47 PM
Mcmopar's Avatar
Good catch, right now Dave only builds a triple or single.
Hey, but so does DTT!!
Just messin with ya Blue!!
Old Jan 4, 2007 | 05:01 PM
Mcmopar's Avatar
I tried requesting info, the e-mail won't go through!!
Old Jan 4, 2007 | 05:10 PM
t-boe's Avatar
I won't even come close to claiming I know something about bombing a CTD. But I know a B.S. artist when I see one. Just by looking at his sig he sounds like guys I new back in high school that said they put a Holley dominator on a Chevy inline 6 and made 1000hp without any other mods. If your spouting off at the mouth like that the truck probably isn't worth half that, if it still runs.
Old Jan 4, 2007 | 05:40 PM
one54ton's Avatar
B.s.............................
Old Jan 4, 2007 | 06:57 PM
Begle1's Avatar
So member RJohnson can make 632 HP/ 1533 ft-lbs with BD twins, a Smarty, a TST COMP, water/ methanol injection and Mach 4 injectors.
How is that perfectly legitimate, but the same set-up with Mach 6 injectors isn't? The guy never said that he wasn't having cooling issues; rather, he said he had his wastegates set up to open early so that he wouldn't have cooling issues.
And by any means, the consensus is that he is making at least 600 horsepower, right? Great deal notwithstanding.
Old Jan 4, 2007 | 07:20 PM
TxDiesel007's Avatar
I dont doubt Rjohnson
the proof is in the dyno sheets, What i dont understand, is how a simple change in valve springs pushes the TQ readin 300 or so ft lbs...
Rick
Old Jan 4, 2007 | 08:39 PM
kelownadiesel's Avatar
it says 700 hp .No way hes burning/cooling that with a set of 300's without nitrous or water.
R johnsons truck is running a water/meth setup and makes about the best numbers Ive seen a set of bds make.His injector turbo combo seems to be perfect
Old Jan 4, 2007 | 08:47 PM
Begle1's Avatar
You know what, I just realized that the truck in the OP doesn't say it has water injection...
Old Jan 4, 2007 | 09:18 PM
dieselfan's Avatar
it says a lot of stuff that it dosent have. like mach 6's when he has jammer stage 5's.here is his sig
Storx
*Dyno 4/11/06*
1/8th 8.45@98mph
1/4 12.85@112mph
Old Jan 5, 2007 | 08:04 AM
I like the headers.
