Sponsored by:
Sponsored by: CARiD
3306 cat
Old Jul 7, 2019 | 02:51 PM
michael sims's Avatar
3306 cat
: I have a 3306 I top off coolant it blows out 2 gallons but don’t overheat steam comes out of overflow is that a head gasket problem
Old Jul 7, 2019 | 04:51 PM
Fordzilla's Avatar
A test with an electronic sniffer for combustion gas in the radiator should answer that question......Ben
Old Jul 8, 2019 | 03:50 PM
AlpineRAM's Avatar
You can also use ph test strips on the coolant- take a reading from fresh coolant and compare with used coolant at low hours- more acidic usually tells you that CO2 is getting into the coolant.
On the Cats I saw some bad T-Stats overheating the engine in the head, the steam in the head pushed the coolant out of the overflow, while the temp gauge read low..
12valve
Apr 28, 2012 05:32 PM
NE frmhnd
Big Rigs
Nov 27, 2011 11:47 PM
jzangger
Big Rigs
Jan 20, 2011 09:34 PM
dzl_damon
Big Rigs
May 19, 2010 09:55 PM
BlueDually
Nov 18, 2007 08:38 PM
