Sponsored by:
Sponsored by: CARiD
2011 PSD/2010 CTD comparison
Old Apr 14, 2010 | 08:35 PM
2171CTD's Avatar
http://www.motortrend.com/roadtests/...son/index.html
Its a Motor Trend comparison, but still pretty decent.
Old Apr 14, 2010 | 08:59 PM
wcbcruzer's Avatar
Powerstroke = Celeron (sounds good to the average Joe)
Cummins = Pentium (quality)
Old Apr 15, 2010 | 01:45 AM
boostjunkie1's Avatar
The review was pretty good. I agree with the auto transmission comments and the ride quality. The Ford gets better mileage loaded than it does unloaded? ????? Really? For the Ford to have more power it does not perform all that much better. The rear leg room is better in the RAM and the Cummins is proven....... plus you save $8,000 + with the RAM. NO BRAINER THERE
Old Apr 15, 2010 | 05:17 AM
Blake Clark's Avatar
Good God some body beat that Ford with an ugly stick....
That grill
If its that close, Ill take the tried and true.
Old Apr 15, 2010 | 08:14 AM
rip 112's Avatar
Yea I'd go fo the engine that has the head start on things. 6.7 has been compliant for emissions since 07.
Old Apr 15, 2010 | 08:18 AM
rich's Avatar
they want a real comparrision let me have each for a week then you can get real info
Old Apr 15, 2010 | 10:19 AM
klx650a2's Avatar
It was interesting that when ford tested the 2 trucks (in another test), their truck got 4 to 6 mpg better fuel economy than the dodge. Yet when MT tested it, it was only 2/10ths better. The review of the tranny was interesting as well. Said the ford was smoother shifting. If I'm towing heavy, I do not want a tranny sliding between shifts so its smooth, to me, sliding equals heat. Give me a good firm shift. For 10 grand cheaper, give me the dodge as well...
Old Apr 15, 2010 | 04:18 PM
Northern Light's Avatar
Have a look at this thread in the 4th gen section:
https://www.dieseltruckresource.com/...m-t267887.html
Old Apr 15, 2010 | 06:04 PM
pwrtripls1's Avatar
I agree, I'd take the Cummins over the Ford anyday. But I am curious how fords in house 6.7L will do in the long run. I've done alot of reading on its development and it actualy looks like a very strong motor. They seem to have fixed the issues that plauged the navistar motors before it. It also has one of the strangest turbo's I've ever seen!
On a side note, according to GM the 2011 Duramax will be pushing 397hp and 765tq, and run 680 miles highway on a 36 gallon tank! Just imagine the possabilities with aftermarket mods........
Old Apr 16, 2010 | 02:03 AM
Jeff in TD's Avatar
Doesn't mention how much urea it uses, or what it costs...
Old Apr 16, 2010 | 09:48 AM
pwrtripls1's Avatar
Urea averages $6.50-7 a gallon. I believe it holds 7 gallons and supposed to run up to 7500 miles on it. So your looking at an added $49 every oil change to fill up the urea tank. BUT we all know most diesel entheusiasts are going to get a tuner that will delete the urea and DPF.
Old Apr 16, 2010 | 11:05 AM
Lil Dog's Avatar
I have a problem with the HP wars now. Most of us up the power to this level because we are going to use it or at least have a handle on it. I can't imagine the trouble a soccer mom can get into with a jacked 4X4 on wet pavement with 400 hp...
Oh and the mileage thing is a real problem too. Unless they have re-invented the combustion process, it still is going to take 150 hp to push that large vehicle down the highway. So unless they are getting free heat energy from that 5th radiator, I don't know how you can do it that much better.
Old Apr 16, 2010 | 11:39 AM
pwrtripls1's Avatar
Well there are a few ways they can increase the mpg and efficiency of the newer diesels. One is the higher injection pressures and piezo injectors, they do a better job of atomizing the fuel for a more complete burn. Second is the fact that compression ratios keep dropping. This means they can run more base timing than the older higher compression engines, while still maintaining simular cylinder pressures. That also increases HP and efficiency of the combustion process. There are other improvements they have made, but those two are the major things that will increase mpg and power at the same time.
Old Apr 16, 2010 | 02:45 PM
BROKER's Avatar
http://www.youtube.com/watch?v=IIRn4uprQdY
http://www.spartandieseltech.com/DSCN0277.AVI
Old Apr 16, 2010 | 07:30 PM
Well,
At least it will sound ok as long as you can keep it running.
