Sponsored by:
Sponsored by: CARiD
1/2 gas 1/2 diesel
Old Oct 3, 2007 | 09:30 AM
cheapskate's Avatar
1/2 gas 1/2 diesel
went to an old tractor/equipment junkyard last weekend, just to look around. some weird stuff there, including this. i saw it from a distance, and said "that looks like a big v-8 diesel". then i looked at the other side. that side was a gasser! it used to power a large air compressor made by leroi, for the military. first pic of the diesel side, second pic of the gasser side.
Attached Thumbnails 1/2 gas 1/2 diesel-s5002569.jpg   1/2 gas 1/2 diesel-s5002570.jpg
Old Oct 3, 2007 | 10:36 AM
lastchance's Avatar
I bet that sucker was a you know what to time!!!
I wonder how they got the motor to balance running???
Old Oct 3, 2007 | 10:45 AM
infidel's Avatar
International made diesel engines that started on gas, spark plugs and all, then switched over to diesel for many years. The stock gasoline "tank" was a quart glass jar.
Perhaps that's what you saw.
Old Oct 3, 2007 | 11:02 AM
cheapskate's Avatar
no, i know what the international engines were. i have seen i ton of md's. this is totally diffferent. look at the pictures. one bank of the v-8 is diesel, the other is gas. i doubt that that both banks were intended to operate at the same time. i assume that if the only fuel available was diesel, one would run it on the four diesel cylanders, vise-versa if the only fuel available was gasoline.
Old Oct 3, 2007 | 11:44 AM
OneBigDoofus's Avatar
Kinda looks like a air compressor to me.....
Old Oct 3, 2007 | 11:54 AM
Dodge359's Avatar
Is that kinda like the old Mack stuff that two identicle but separate electrical systems?
Old Oct 3, 2007 | 12:30 PM
Was there a crank driven compressor at either end of the crank?
The side that y'all say looks like a diesel, looks like the cylinders that compress the air to me,.....if exhaust wus flowing through that manifold then it wasn't very hot.....still has paint. Maybe that is the intake for the diesel , but it sure is small for an Intake.
I'll be quite now LOL
Old Oct 3, 2007 | 08:08 PM
1-2-3's Avatar
Just a plain ole guy
I'd bet that it was a complete compressor. 4 cylinders ran on gas, the other 4 were the actual compressor. I've seen a Ford v8 setup like this before. The top of the cylinders on a deisel engine would not be linked with copper tubing.
Old Oct 3, 2007 | 08:31 PM
Lil Dog's Avatar
Agreed with charliez. I have used a compressor made of a 302 Ford. 1/2 engine and the other half air compressor. Looked just like that...
Old Oct 4, 2007 | 05:43 AM
JD730's Avatar
I too agree with charliez, what you see linked together with tubing is actually the unloading valves.
Old Oct 7, 2007 | 02:08 PM
Wow!!! You guy's are tuff on a newbie around here. LOL
Wha? Nobody was to agree with me?.....
"I concur with the BigDoofus"
Well now that i've said that outloud, maybe I see why,....
Old Oct 8, 2007 | 01:18 PM
PoorMansCat's Avatar
Seen one in mounted in the bqck of a 1/2 ton Ford tire truck... It was a Buick V-6 with a radiator and cooling fan out of a 4 wheeler...... Gotta understand, I DO live in downtown Redneckville.... hahaha....
cappykd
Jun 23, 2008 04:45 PM
THURENfab.
Aug 8, 2007 07:02 AM
Scovo1
30
May 11, 2007 01:08 PM
04ctd
15
Apr 30, 2006 08:45 AM
