Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
WVO storage, how long, how, can I ??????
Old Jan 27, 2008 | 01:18 AM
dieselcarpenter's Avatar
Question WVO storage, how long, how, can I ??????
I think I finally have source for WVO, how long can I store it before processing it? What do I need to do to store it? Will it go bad? The reason I need to store it is because I don't have a processor yet. I want to stock pile the stuff first. Any advice??
Old Jan 27, 2008 | 01:25 AM
biododge1's Avatar
i think as raw oil it will keep a long time. i have oil in drums outside from last year and it's still good.
Old Jan 28, 2008 | 08:36 AM
kawi600's Avatar
Id just use airtight drums and fill them completely.
Oh yeah, you might also look on sites like utahbiodieselsupply for some biocide thats ok to use with biodiesel or WVO.
You could pre-process the stuff before storage too. Remove all the water and solids with a vacuum / heat /filter process. Then you know right out of the barrel its good to go.
Old Jan 28, 2008 | 09:19 AM
high bid's Avatar
From what I've heard it will go rancid after sometime. Obviously the conditions it's stored in will determine the length of useable time frame.
Outside and sunny 80deg= not very long
Inside and dark 70deg=probably months of useful life, maybe more
Old Jan 28, 2008 | 02:17 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Stored WVO for 8 months in a dark cool place...No problem...I think it would take a long time before the oil goes bad...
Old Jan 28, 2008 | 02:49 PM
high bid's Avatar
Agreed but were also talking Canada vs. Texas which could mean a diff in temps of 50+ degrees at any point in the year. Either way you best bet is to store it sealed in doors...preferably in a metal drum.
Old Jan 28, 2008 | 08:22 PM
Hammily's Avatar
It will keep longer if you can clean it before you store it. If you have losts of junk in the oil it will go bad much faster. Dark cool place is the best idea. I've always stored mine in plastic drums.
Old Jan 28, 2008 | 08:45 PM
rjm022's Avatar
i strain mine first to get the food particles out. then make sure the oil is in air tight containers and store away from sunlight, in a cool spot where it will not freeze. can keep up to a year. that is what i have read on the biodiesel sites.
GRASS CUTTER
Jun 21, 2007 04:25 PM
csramsey640
Jul 7, 2006 08:05 AM
JKM
May 6, 2006 06:52 PM
pakman
Dec 12, 2005 10:26 PM
The_g10
Oct 13, 2003 09:29 AM
