Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
What oils for Biodiesel.
Old Feb 18, 2009 | 11:20 AM
dstad's Avatar
what oils can you make bio diesel out of im looking at this one.
http://www.homebiodieselkits.com/4gastkit.html
Old Feb 18, 2009 | 11:34 AM
kawi600's Avatar
You can use any plant oils for it, but some are more common and cheaper to get. The most common will be soy oil, which is ok for spring through fall and will probably gel under 40F.
Canola usually makes better fuel for cold climates.
There is also the oils iodine value which relates to how much polymerization can occur. I think canola was okay in that regard as well.
Old Feb 18, 2009 | 11:37 AM
dstad's Avatar
all i have is a bunch of resturants to go and bug. do you think their oil is good enough?
Old Feb 18, 2009 | 11:50 AM
~Angry Tractor~'s Avatar
I have always read that used cooking oils work better then new cooking oils for some reason.
Old Feb 18, 2009 | 01:40 PM
annabelle's Avatar
Do the quick test which Girl Mark recommends.
Old Feb 19, 2009 | 08:16 AM
kawi600's Avatar
Do a titration test on all the oil youre lookin at and also test for water content. Both of those will factor into the decision
Old Feb 19, 2009 | 09:43 AM
infidel's Avatar
all i have is a bunch of restaurants to go and bug. do you think their oil is good enough?
Many cheap restaurants and fast food joints use lard instead of plant oil.
Makes lousy bio.
Old Feb 19, 2009 | 09:54 AM
John Faughn's Avatar
I think your not going to have much choice , to get enough to really use/need , you may need to just take what you find , then classify / separate as you collect .
If you end up having to pay , then invest in a testing kit , so that you can judge the value of what they have .
Any oil from either plant or animal will make bio , the difference is the amount of resources [ used to make ] & quality that you end up with .
Old Mar 2, 2009 | 11:39 AM
JustLuckey's Avatar
I use the waste (soybean) oil from 2 different chinese restaurants.
Watch out for restaurants that use 'shortening' instead of oil. It's not good quality for making biodiesel.
Also, when you make arrangments to start picking it up, make sure they understand that it can't have water in it or other (cleaning) chemicals.
ramlovingvet
Sep 10, 2003 07:46 PM
finallydiesel
Aug 9, 2003 08:22 PM
azjeff
Jun 29, 2003 10:57 AM
Hoss
Jun 20, 2003 08:01 AM
