Vegeterrainian
The vegeterrainian kit is a two tank system for running straight vegetable oil(SVO) or waste vegetable oil(WVO). NOT a biodiesel reactor.
Copper and brass are both metals that should be avoided for a svo/wvo system as they react with the VO.
Also this is a generic kit and will not have everything needed for converting like a lift pump for those with 24 valve Cummins engines.
The price is relative. The ~$1500 may seem inexpensive but what are you getting?
The questions that come to mind are:
what is the flow rate of their filter?
is there a tank heat exchanger
What fuel temperatures are you wanting to have pre IP?
I guess its time for me to give up trying to make a point [ that does not mean you have to accept it , just understand it , then use your judgment ] one more time , the lack of not taking out the gliserin is problumatic , getting WVO in a usable condition [ this is were I'm not convinced it can be gotten to ] by the better of the 2 tank systems , method [ cost /labor ] is not much different .
John,
As stated before in this thread, VO doesn't have gliserin. Gliserin is a by product from making biodiesel.
Do you know of any person first hand that has experienced engine problems from running a 2 tank heated VO system? I'd be very surprised if you do since it is very rair with a proper two tank system.
With a single tank system problems are much more likely and usually start with injector coking and leads to ring land coking.
Lots of misinformation there , the reason there is a byproduct of gliserin , is because thats what the process is for , to remove the gliserin that is in all vegi oil , its called transesterfication , adding a mixture of lye & methonal , to settle out the gliserin that was there at the begining .
The varyouse methods of using unprocessed vegi oil new use what ever , the more evolved systems are trying to mitagate the glisein , 2 tank-flush , preheat , ect. , affecting less coking , ash , unburned ,
By the time any of these methods get close to burning the gliserin , you
've spent about the same time and money , and are still dealing with the origanal problum , the gliserin ,
http://www.missouri.edu/~pavt0689/leon.html
Leon Schumacher's Home Page
http://www.missouri.edu/~pavt0689/index.html
BIO-BASED RESEARCH HUB
http://journeytoforever.org/biodiesel_yield.html
Vegetable oil yields, characteristics: Journey to Forever
http://www.localb100.com/
LocalB100
LocalB100
LocalB100
LocalB100
you are correct, the glycerin is in all vo. it is what makes the vo 'sticky'
It burns cleaner than diesel so your oil stays cleaner, but I still change mine at the regular interval. So far I have had no problem with coking. It might be because I run power service every tank and seafoam every once in a while. There is a good long thing on TDR where the guy has torn down and at least pulled injectors to see the effects.
