Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Speed & MPG
Old Apr 15, 2006 | 07:44 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Speed & MPG
Little test.
In February, I drove from Norfolk/Virginia Beach area.
Filled up to the neck, reset trip odo, drove home with cruise set at ~2100 rpm (approx 65 mph).
Refilled to the neck near the house.
Using a 4% error factor to compensate milage for the taller 235 tires achieved 20.5 mpg.
Today,
Filled up to the neck, reset trip odo, drove ~320 miles @ speeds averaging about 75 mph.
The only difference was speed and the fact that today I had Wifey with me.
(That explains the higher speeds....she hates it when people aren't in the fast lane at full-boogie)
Using the same 4% error factor to compensate milage for the taller 235 tires achieved 17.9 mpg.
Speed Kills (fuel milage)
Also noticed that the same fuel station that had diesel priced @ $2.69 gal at 10:00 this morning had dropped it to $2.59 gal by 7:00 this evening.
Old Apr 15, 2006 | 09:00 PM
edwinsmith's Avatar
Yep. More speed = More drag. More drag means more power to overcome the drag. More power takes more fuel.
Wheels and tires make a big diff also. Duallys get worse mileage because there are two more tires on the road and a little more air drag. The width of the tire makes a difference too. This is why racing bicycles have those skinny tires. Easier to pedal.
But then you already knew that.
Old Apr 16, 2006 | 10:01 AM
infidel's Avatar
Cummins gets technical about the effects of speed and other factors here
http://www.everytime.cummins.com/eve...Whitepaper.pdf
Old Apr 16, 2006 | 12:39 PM
Begle1's Avatar
You drove at 65 MPH for 320 miles?
You can even set the cruise at speeds that low?
I get 16 averaging 80 on the freeway and I get ~14 driving as recklessly as possible around town.
Even at 80 with the 1st gen body, 16 MPG with a 3.07 rear end always strikes me as a bit low...
Old Apr 16, 2006 | 12:43 PM
Shovelhead's Avatar
Now add two more wheels on the ground, and the extra weight of the quad-cab, coupled with an auto trans and a 4.10 gear.
Old Apr 16, 2006 | 09:02 PM
bluebull's Avatar
I've often wondered about those 2 extra wheels. Do they actually decrease fuel mileage?
I have not sat down and figured it out but.
If you take stock trucks the duallies come with narrower and shorter tires than what are on stock SRW trucks. Now if you take the the actual rubber from each tire and rotational size differences is there really that much difference between duallies and none duallies as far as mass and power to drive each set?
Old Apr 16, 2006 | 09:21 PM
Geico266's Avatar
What were the wind dirctions when you were traveling? Wind has a huge effect on milage also. Going 65 MPH with a 20MPH head wind is like going 85MPH.
Old Apr 16, 2006 | 09:43 PM
crobtex's Avatar
I always bust 20+ on the highway when I keep it just below 65 mph. Anything above that and it degrades with the higher speeds.
Did you say the price dropped?
Old Apr 17, 2006 | 05:21 AM
Shovelhead's Avatar
You also have the additional wind drag from the wider combined cross section of the tires and the wheelboxes.
Wind was not really a factor either run <5 mph (slight breeze)
Old Apr 17, 2006 | 09:43 PM
WideOpenThrottl's Avatar
I've noticed apprx. the same difference in milage going from 60 to 75-80mph. but now with the dynomite injectors I've been able to pull a hair over 20mpg at 75-77mph. I never could get that before at them speeds with stock injectors.
Tim.
Old Apr 18, 2006 | 02:01 AM
Chrisreyn's Avatar
I've noticed that if I drive at 60-65mph, turning about 1800-2000 rpm, I get MUCH better mileage than if I drive 70-75 mph turning 2250-2500...
I have decided its worht the $$ to take my time getting places...
A 500 mile trip( Topeka to Denver) at 70 mph will take 7.1 hours...
at 65 mph it takes 7.6 hours...not that much of a difference....
royta
15
Mar 3, 2010 09:28 PM
bngcustoms
45
Jun 20, 2009 06:55 PM
richard
26
Sep 6, 2007 01:35 PM
bigfish5
Sep 19, 2006 12:56 AM
stroker
20
Jan 12, 2003 08:51 PM
