Running Waste Oil?
Howdy! New to the forum...
Just traded my 01 F250 PSD for a 04.5 CTD 2500 4X4!
I love the truck but miss the room!
I ran used waste oil in my PSD for about 30K miles at a 45% mix. No Loss of power or mileage. I mixed diesel and motor oil in a 55 gal drum and used a 12v pump to circulate it through a TP Bypass filter for a couple of hours and then through a regular fuel filter into my 60 Gal auxiliary fuel tank. I just started mixing different %'s until a got to 50% and noticed some smoke during acceleration (more than normal) and then backed off a notch.. Bam! 1/2 priced Fuel!
I just installed the tank in the Dodge and I am going to rig it up so that the stock fuel gauge will work when I switch over to the aux tank... Sweet Setup from Northern Tool >> But cost a bunch!
I love the Forum... Very informative and not as many poeple complaining about ther truck!! To Tell you the truth... That is the main Reason I Choose the Ram!
OilGuy
OilGuy
Guest
Posts: n/a
Please keep me posted on how this mix does in the new Dodge. I am interested in doing this and have run much lower percentages with no problems but 45% that would save a lot of $$$. I have access to waste oil and I am thinking the my FASS with the extra filtering plus water seperator should filter out all of the junk from the wadste oil that I dont want in the motor. With fuel so high there has got to be a way to run waste oil safely.
Cummins says 5%, and the old rule of thumb was 10% max. My 3208 will start banging at 20%. I would not think of going over 5%. It will give a bit more mileage with it in.
I get about 600 gallons of used oil a week, never heard of dumping it in the tank. Other than geting rid of waste oil what are the main advantages of this?
I originally got the idea from a dodge forum thread (not this one) where people were mixing 30 to 50% in their truck with some that have gone 80+K Miles and if I remember right there was one that had closer to 200K miles with no related problems. I will dig around to see if I can find it again but I was looking for WVO information... Also you can Googe "Black Diesel" and get some information. I have an endless supply of waste oil (Quick lube business) and got really excited when I found this!
OilGuy
OilGuy
Top's Younger Twin
How would this work in cold climates? Would we need to heat the tank to avoid clogging or does oil and diesel have similar characteristics in the winter?
I know 15W40 is thick when its cold. Wondering what issues I might encounter if I did this.
Scotty
Scotty
If you were to try running a high percentage in cold weather you would have problems. Oilguy doesn't have winter as such.
Scotty, if that truck still has a cat the extreme pressure additives in the oil will cause it to stop working. I feel like if it's gonna be on there you shouldn't ruin it.
Yup... No winter here... Hot and dam hot are the seasons here in Texas. However I try to only run lighter weigh oils and as little syn as possible.. Too many friction modifiers >> They don't burn very well... I also run the aux tank and leave the stock tank with pure diesel so if my blend causes smoke I just run it on the highway and then switch when I get in town to keep it from smoking at idle. Then after I run the tank down a bid... I top it back off with pure diesel to dilute it. This is probably not a project for eveyone... just those of you that can deal with everyone thinking you are crazy!...
WannaDiesel... I see that you have a water/meth setup on your rig... Do you like it??.. I am thinking of puting that on mine before I go back with the fuel/oil mixture.
OilGuy
OilGuy
For WVO info here is a good place to look
http://www.frybrid.com/test.htm
Also check out;
http://biodiesel.infopop.cc/eve/ubb....51&f=159605551
Ken
Also check out;
Ken
I have been running drain oil in my 90 for as long as i have had it (bought new)
it now has over 300k with the same IP and Injectors ,and runs like a champ, but i think its time for new injectors cuz my MPG is way low
OilGuy
OilGuy
Ok guys, Im kind of new to this. I drive an old gmc diesel but, next month im buying a used but new to me 98 to 03 dodge CTD. This is the first ive heard of this. so tell me if i have this right? You can actually add a percentage of used filterd diesel oil into the fuel and run the truck on this as long as the truck does not have a cat on it?
