Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Methyl Alcohol, Methanol, Nitro Methane....
Old Feb 8, 2009 | 01:22 PM
Swamp_Donkey's Avatar
Because the names are different, this methyl alcohol that is in windsheild washer fluid as good as mixing my own pure methanol. Also trying to do a little research on nitro methane, and from what I can gather, it does not mix well with other fuels. Does it seperate out? Just trying to maybe add a little nitro methane. From what I have seen there is someone who had a 50% water 48% Methanol and 2% Nitro Methane.
Old Feb 8, 2009 | 03:33 PM
infidel's Avatar
Doesn't answer your questions but lots of folks use washer fluid injection to lower egts.
The colder the fluid is rated for the better.
Surprisingly the -40°F fluid we get in the northern states isn't even sold the further south you go.
Old Feb 8, 2009 | 05:55 PM
Upon some wikipedia searches I found out that methyl alcohol and methanol are the exact same thing......
Old Feb 8, 2009 | 06:18 PM
mishkaya's Avatar
I was just about to post that. I use methanol in large quantities. Don't use it on the truck though...
mishkaya
Old Feb 8, 2009 | 08:59 PM
madhat's Avatar
Administrator/Jarhead
If you are looking for a methanol source, get heet gas line dryer in the yellow bottles. I e-mailed them, and they said that it was 97-98%.
I use this in my water/meth, not in my fuel...
Old Feb 8, 2009 | 09:10 PM
mishkaya's Avatar
That gets quite expensive though, better off finding a place that sells racing fuel as it tends to be quite a bit cheaper for 100% methanol.
mishkaya
Old Feb 8, 2009 | 09:30 PM
madhat's Avatar
mishkaya
True, but I don't run it unless I'm at the track.
Straight water works great for daily stuff.
Old Feb 9, 2009 | 10:46 AM
infidel's Avatar
Must be an easy way to remove the water from washer fluid.
I buy it all the time on sale for 99¢/gal.
That would get the price close to $2/gal.
Not sure if that's good or not.
Old Feb 9, 2009 | 01:31 PM
mishkaya's Avatar
There is no easy way to remove the water from the washer fluid as Methanol is hygroscopic. Also, I doubt that the washer fluid has 50% methanol in it ( as that would give you a -60F protection), and that gets expensive. Most washer fluids contain between 35% and 45% methanol.
mishkaya
Old Feb 10, 2009 | 04:09 PM
dkenny's Avatar
it could be distilled, but its still not easy.
I distill the extra methanol from my glycerin.
-dkenny
drewblood
Feb 3, 2008 06:16 PM
Big Blue24
81
Jan 21, 2008 03:03 PM
Teddy Bear
Oct 15, 2006 09:50 AM
