Anyone running biodiesel?
There's a whole forum dedicated to biodiesel on this site. It's good if you make it right. You'll have to change some fuel lines cause bio eats rubber. Other than that you'll have to replace the fuel filters a few times after you run bio for the first time. BTW, don't breathe the methoxide. It's TOXIC.
I've been trying to put together a list of materials required to see if a kit is best or if piecing one together will save some bucks...
Also trying to decide between the 'appleseed' type system or the more industrial poly cone containers...
See benifits to both... appleseed with the hot water heater is designed for heating and already insulated... easy to plumb etc...
poly type looks better imo and you can see the separation more easily..
i don't know what I want to do... No matter what I do it looks like an easy grand to get set up... Costs for brewing your own range from .50-$1 a gallon depending on the quality of oil you start with... At that cost it would take about a year to pay the system off... Decisions...
You should be able to build a appleseed processor for way less than a grand.Seems that the guys who build these ,the cost runs about $350.My processor is a steel 5 gallon pail with a water heater element.I have made over 2000 gallons.Sure wish I had more room to build a bigger processor.But the little processor works fine...
This is something I've been contemplating for a long time. In the end I feel like it's just worth buying #2 even if it is more expensive. However, the idea sparks up again in my mind everytime I read about it. One thing I'm concerned about though is the methoxide. I don't want to be near that stuff...
I used a 50 gallon hot water heater for the tank, and two 50 gallon plastic tanks for the washing tanks. Tank was free (put a new one in the house for $200, cleaned the old one out for this use), barrels cost me a case of beer, water pump, fittings, hose, bubblers, spray nozzles, wood, gauge, valves etc maybe $200 to $250? I'll have to see if I can find some pics...
I made it over a year ago, haven't wired up the water pump or heater yet. Didn't have a source for the oil at the time. Yesterday I picked up 150 gallons of WVO to get started when I find the time...
maninblack2k
Jun 20, 2010 10:23 AM
sakisaki400
Mar 10, 2008 12:38 PM
mm73
Nov 2, 2007 05:41 PM
LuciferX
16
Jul 28, 2006 09:12 PM
Teachwood
17
Dec 11, 2004 01:34 PM
