FCA o-ring sizes
Old Nov 8, 2008 | 09:07 AM
MikeyB's Avatar
FCA o-ring sizes
Anyone just happen to know the sizes for the o-rings on the FCA?
I check my FCA a few weeks ago and now it's leaking pretty bad.
MikeyB
Old Nov 8, 2008 | 10:09 AM
madhat's Avatar
Administrator/Jarhead
I dunno, but I can give you the one off my old one if you like... I have a perfectly good FCA sitting in the shed with no where to go...
Old Nov 8, 2008 | 11:06 AM
MikeyB's Avatar
Madhat,
Thanks for the offer. I just need the measurements (thickness and OD in mm).
I'll pickup some viton o-rings locally.
MikeyB
Old Nov 8, 2008 | 01:04 PM
madhat's Avatar
I don't have anything to measure the thickness... sorry... Just take the dang thing out and use the wife's car... that's what I do when I break....stuff
Old Nov 10, 2008 | 07:11 AM
MikeyB's Avatar
FYI.
I had a heck of a time finding one of the o-rings. The smaller one is a 2mm x 9mm and is pretty common. The other is a 2mm x 11.5mm. After going through many kits I found one that's pretty close in size to the original. It's in a A/C compatible kit and the size I believe was a 3mm x 10.5mm.
Hopefully this will stop the leaking FCA. Already noticed the truck doesn't smoke as much like before.
MikeyB
Old Nov 10, 2008 | 07:22 AM
38short's Avatar
Fca
Excuse me for butting in Mikey.I've got a slightly rough idle use lucas regularly along with 2 cycle oil would removing the FCA aand cleaning it help??What torx bit size is it and where can you get replacements here in Houston.Thank you,any help appreciated.
Old Nov 10, 2008 | 07:32 AM
MikeyB's Avatar
Don't know if cleaning the FCA will solve the rough idle. If you remove the FCA make sure to have new o-rings on hand. I nicked one of the originals when installing and it leaked pretty bad with lots of white smoke from the exhaust.
Anyway, the screws are T25.
You can get the FCA from Cummins Southern Plains over on the North Loop.
Or you can order one from Hoeslidiesel.com
MikeyB
Old Nov 10, 2008 | 09:28 AM
madhat's Avatar
If you replace the FCA, go with an aftermarket one, they are not too bad $$ wise, and you'll get the extra performace...
cincydiesel
17
Feb 22, 2012 05:36 PM
draskobnsf
17
May 29, 2007 08:29 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
