Just Released - DiabloSport Trinity T-1000
Vendor - Former Vendor
Looking for a mileage booster for your Dodge 5.7L? DiabloSport just announced the release of tuning support for the 2011 Ram 1500/2500 5.7L trucks. With the updated Trinity T-1000, you can now modify stock, get 3 different octane performance tunes and also a mileage booster tune. The specs of the tunes and capabilities are as follows:
93 Octane Performance Tune
This tune is designed for use with premium fuel. The Performance Tune will unleash the maximum available Horsepower, Torque and Economy out of your stock vehicle with no other mods necessary! Vehicles will see a power across the entire RPM range with the greatest gains down low. Vehicle will also see improvements in drivability, throttle response, and economy.
30HP
35TQ
91 Octane Performance Tune
This tune is very similar to the Performance tune for 93 Octane but optimized for 91 Octane Premium Fuel. Vehicles will see a power across the entire RPM range with the greatest gains down low. Vehicle will also see improvements in drivability, throttle response, and economy.
28HP
33TQ
87 Octane Performance Tune
This tune is designed for use with 87 octane gasoline. It will increase HP, TQ and Fuel Economy without the need to run premium fuel in the vehicle. While HP Gains are not as great as in the 93 octane Diablotune, this tune wakes up your vehicle’s throttle response, power, and improves overall driveability.
18HP
20TQ
Mileage Booster
The Mileage Booster tune optimizes efficiency for daily use. Horsepower gains will be minimal, but mileage will improve by up to 3 MPG in some applications! Compatible with fuel that is 87 octane or greater.
Modified Stock
This tune is designed to work with a stock vehicle and keep the stock HP and TQ ratings. Use this tune to have factory drivability but modify the parameters of your vehicle's calibration such as speed limiters, rev limiters, tire size and more.
The adjustable parameters are:
Calibrate Speedo for Tire Size
Shift Points
Cooling Fan Control
Fuel Rich/Lean Adjustment
Spark Timing Advance/Retard
Idle RPM
Active Fuel Management Disable (8 to 4 Cylinders)
Rev Limiter
Speed Limiter
Throttle Booster
Tire Pressure Threshold Adjustment
Torque Management Adjustment
This tuner is in stock! Be sure and get yours today, they are going fast!
Diablo Trinity T-1000
30HP
35TQ
28HP
33TQ
18HP
20TQ
Mileage Booster
Modified Stock
Shift Points
Cooling Fan Control
Idle RPM
Rev Limiter
Speed Limiter
Throttle Booster
Totallyrad
29
06-20-2017 11:23 PM
InfernoMega06
31
05-25-2012 06:03 PM
MegaBOMB
08-10-2006 10:05 AM
01350banshee
19
05-05-2006 07:16 PM
