Won't start
Old Apr 1, 2013 | 08:32 PM
Hi Pockets's Avatar
Won't start
I just finished a 2003 cummins in to a 2001 Ford. I used all Destroked parts, including the wiring harness. The engine ran when I took it out of the Dodge four months ago. Now that is time to start it. The dang thing won't start. It cranks and will run for a while on starter fluid. Any suggestions would be great.
Old Apr 1, 2013 | 11:18 PM
Lenny Boysen's Avatar
Are you trying to run it off the Ford Computers?
Old Apr 2, 2013 | 07:17 AM
Hi Pockets's Avatar
Ford computer
I'm using the Dodge ECM with Ford PCM. Levi at Destroked did the wire harness.
Thanks for the question.
Old Apr 2, 2013 | 11:07 PM
I don't know if you got a way to view data-but theres a few things i would check-Make sure you got good Crank and cam Sensor signals,and verify throttle position sensor,make sure its not reading 100% with blade closed. If all that checks out good,sounds to me you have a fuel delivery issue,or alot of air in your lines still
Old Apr 13, 2013 | 08:45 PM
Hi Pockets's Avatar
Got it started
Took the Smarty Jr out and it fired right up!
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
